Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Dimal
Thread: Removing the Lower Boiler Joint (jet breaker) from Lelit
    Aug 2007
    260
    Does anyone know how to remove the Lower Boiler Joint from a Lelit/Quaha/Imat etc without damaging it?
    It is supposed to unscrew but I can't seem to loosen mine without damaging it (it is soft brass).
    It is part # MC138 and channels the water into 4 x jets before hitting the showerscreen.
    Taan
    17,122
    You've checked out this helpful webpage I take it Taan...
    Vinitasse likes this.
    Aug 2007
    260
    Thanks Mal,
    Yes have seen it but it doesn't specifically mention removal of the lower boiler joint.
    I was just hoping someone else had already tried. Picture of part I'm trying to remove below.
    17,122
    Ah, Ok...
    I bought a large straight edge screwdriver from SuperCheap and then ground it down so that it was a very neat fit into the slot of this fitting. After applying a little heat from a small butane torch and then using the custom screwdriver, it came off quite easily...
    Hope it does for you too...
    Aug 2007
    260
    Thanks Mal,
    Just the info I was after.
