Results 1 to 2 of 2
Thread: Over choked Silvia
    May 2014
    75
    Over choked Silvia
    Have I done a pump or just tripped the 3 way.
    Broke my scales and think I had the 21g+ triple in.
    Choked a shot thought it was going to pull through and the it went bang(/pop)
    Now the group head switch sounds the same as the fill boiler both go nowhere unless I open the steam tap.
    What happens
    https://cloud.tapatalk.com/s/57fcb1a2...011_172926.mp4
    Feel free to flame for stupidity
    Sep 2016
    21
    Have you made any progress 6 days later? Everyone chokes up a shot once in a while, can't flame you for stupidity, the machine should be able to handle it.
    The pump is obviously still producing pressure so it can't be that. If it stopped with a bang I would be looking for a split pipe or leaking seal/component inside the machine, something along those lines. There is a path from the pump to the brew head, follow it - disconnecting hoses and run pump if needed, and find out which component it is not making its way past!
    Good luck let us know
