Results 1 to 2 of 2
Thread: Optimum shot weight for La Pav Pro
    Senior Member gonzob's Avatar
    Aug 2011
    229
    My previous experience from a Silvia says that when you get water on top of the spent shot, you probably haven't dosed enough, and when you can't close the portafilter, you've got too much. Then you adjust the grind to get the flow right.
    It's all different with the La Pavoni. Because it dispenses a fixed amount of water you never end up with water on top of the shot. I've tried weights from 13g to 19g and adjusted the grind to make each of them flow properly, and I can get a good espresso across the range. My question is: is there an optimum weight, or technique?
    Gonzo
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,057
    Not sure how you get 19 grams in Gonz, I've found 16 grams to work well for me, allows the PF to lock in without the puck contacting the dispersion screen and provides a very acceptable espresso.
    Optimum, I suspect would be pretty subjective.
