Results 1 to 4 of 4
Thread: Pid help! Rancilio
    Apr 2018
    7
    Pid help! Rancilio
    Hello everyone.
    I've recently installed a Golander PID.
    I'm an electrician and the installation was fairly straight forward and I'm sure if wired it correctly with 2 ssr's to control both brew and steam.
    My issue is with the programming of the pid itself, as soon as I've powered on the machine it jumps straight into extraction and the pump engages.
    It cycles through pre infusion as well but I have no idea how to fix this.
    Would anyone be able to walk me through entering all the parameters that they use?
    Senior Member JMcCee's Avatar
    Feb 2017
    Morningtom Peninsula
    297
    What model Rancilio? Does it have programable touch pads?
    Nov 2017
    Maddington, Perth. Wa
    920
    Did it go straight into extraction before you put the pid on?
    Apr 2018
    7
    Hi guys thanks for taking the time to query me on my issue, but, as it turns out I was hasty in my purchase of the pid and as the manufacturer has informed me it does not have the timer function which I assumed it had.
    Nevertheless, it will work as my temp monitor in my Forget to build.
    $140 later and I've gone with the auber unit I should have originally bought.
    This is what happens sometimes when you're a tight@$$ like me.
