Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Aaron
Thread: Water in the steam - LaCimbali Domus
    May 2018
    Perth
    3
    I've been using my LaCimbali Domus for at least 20 years.
    Today it has decided to add water to the steam coming out of the wand. I have descaled and cleaned, but it is still happening. This isn't just a bit when I first turn on the steam, it is continual, with plenty of steam as well.
    I would be appreciative of any suggestions of what might be going wrong here.
    Many thanks
    Nov 2017
    Maddington, Perth. Wa
    1,016
    What is the boiler pressure?
    May 2018
    Perth
    3
    Sorry, don't know. The machine doesn't have a gauge.
    Aug 2010
    86
    Could be faulty steam thermo.
    May 2018
    Perth
    3
    Quote Originally Posted by bosco View Post
    Thanks - any other suggestions or fixes?
    Nov 2017
    1,016
    Going to have to find the boiler pressure or temperature. But it sounds like its not hot enough
    Apr 2007
    Sydney - Northern Beaches
    412
    In my experience with the Domus I recall that the steam pipe comes off the top of the boiler. In order to get too much water to run out of the steam outlet I think the boiler might be overfilled.
    if the water was too cold I wonder if it would be under enough pressure to be pushed out the steam pipe? Is your Domus the one with the autofill function?
    Can you hear the pump run while you are trying to stream?
    MrJack likes this.
