Results 1 to 4 of 4
Thread: Carimali Uno e water backflow problem
    Jun 2018
    2
    First post, I did search
    I am restoring this uno and was testing it last night by drawing water from a jug, (rotary pump).
    It heat up fine, drew shots as it should, nice steam...but then I noticed the pump was kicking in a lot more than it should. No leaks, then I noticed the water would drain back into the jug,, pump would kick in to fill the boiler again, the water would then drain back to the jug and the process would start over.
    It is obviously bleeding back through the pump, but is there a one way valve in the intake fitting?
    My deductive skills say either the pump should not allow backflow or the intake valve should not allow backflow.
    Any help will be appreciated.
    bob
    Dec 2004
    Earth!
    15,248
    You need to install a one way valve in the line running from the jug to the machine.
    Java "One way to go" phile
    Toys! I must have new toys!!!
    Jun 2018
    2
    I thought of that, wondered if it would be that easy.
    I have used a jug on other rotary pump machines and never had that problem...home Depot here I come.thanks
    May 2013
    145
    A .... water diode? :P
