Results 1 to 15 of 15
Like Tree6Likes
  • 2 Post By nac
  • 1 Post By pcrussell50
  • 2 Post By artman
  • 1 Post By Lyrebird
Thread: Breville Dual Boiler Steam Ball Valve
    Member Martino's Avatar
    Mar 2016
    New York
    77
    Just an FYI: I happened to be on ereplacementparts.com today when I saw the infamous Dual Boiler steam ball valve being advertised again...(BES900 or 920/9.6), see pic. I was quite surprised as the last I looked, it was discontinued by Breville. Then I read the fine print that said ... leaves our warehouse within 18-24 business days. So I called and talked with them. The bottom line is that the only way they (or you) would know if this part would actually be available is to place an order for it, wait your 18-24 days and see what happens.
    If anyone actually does that, pls report back
    I have not been able to find this part anywhere. New Zealand's Need-a-part even shows it as discontinued.
    nac
    nac is offline
    Aug 2014
    13
    I ended up buying a ball valve from Bunnings, then used a bench grinder and file to get it to fit.
    inorog and fdzy like this.
    Mar 2016
    New York
    77
    Quote Originally Posted by nac View Post
    Excellent NAC! So you used both ends (fittings) from the OEM valve, right? and the bench grinder was to shape the actuator so it fit the Breville steam handle, right? How long have you had it installed? Any issues? Can you post the manufacturer and part number of the valve?
    This is what these forums are all about! Love it.
    Martino
    May 2013
    154
    And that's how the FrankenBreville was born! IT LIVES!!
    Brilliant idea! Well done! Echoing the others - could you post some details of what you've done?
    Aug 2011
    southern california, usa
    346
    Noice!!! Holding it with zip ties is brillers!!! I was going to grind mine down a little thinner in the middle to use the stock Breville hold down bracket.
    I was partway through fitting my valve (same as yours) when I found two spares online and bought them both. I think Iíll still finish the job, just for the fun of it, even though I have spares for many years now.
    -Peter
    inorog likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,475
    Very clever. If this valve has the heat and pressure rating needed it should last for ages.
    If you canít mod the normal clamp to fit at least replace the cable ties with steel hose clamps. I reckon The zip ties will fatigue and snap with time especially with the high heat environment. It will be a much more durable solution.
    inorog and level3ninja like this.
    Aug 2011
    346
    I have that valve too. It was under $4 USD on eBay. It was not presented with any specs, and I don't have high hopes for it. BUT... 1) it should still work for at least a little while, and 2) they're easy enough and cheap enough to replace that a somewhat shorter lifespan might still be acceptable.
    Having said that, I also ordered a much nicer ball valve that is much closer to the size and shape of the original Breville bit. We'll see how that one goes, too. It is this one:
    http://www.performance-pcs.com/phoby...4-knurled.html
    -Peter
    May 2013
    154
    @pcrussel50
    Does it have any specs about high temperature? I couldn't see anything on it.
    Aug 2011
    346
    Quote Originally Posted by inorog View Post
    @pcrussel50
    Sadly, I do not. I believe it’s used for hot coolant in the liquid cooled gamer PC community, if that’s any help. But I bet they aren’t at steam temps. However this valve seems to be widely available so somebody might have it. Also, it uses 1/4 BSPP threads (British Parallel Pipe) which are not as common here in the USA as I imagine they might be in Oz. So you guys might have more to choose from than we get. I think if you want to find specs, you will have to pay about four times as much which still isn’t a deal breaker, and you will have to shop actual engineering supply shops, not eBay or Amazon.
    -Peter
    Jun 2018
    625
    Geordi Stainless have 1/4 stainless ball valves rated for steam duty (to ~900kPa steam pressure) for $AUD11.50.
    inorog likes this.
    Aug 2011
    346
    Do they have dimensions? The stock Breville valve is about 39-40mm long without the end caps.
    -Peter
    Jun 2018
    625
    Datasheet (PDF) says 39 mm for the 1/4"
    May 2013
    154
    With a stylish yellow handle, appealing to the seasoned .... industrial steam-punk :P
    Jun 2018
    625
    If you want blue, go to ProChem.
    Oct 2018
    1
    Did you have any issues with the valve logic? I read elsewhere that unlike the typical valve lever inline/open, the stock valve is the opposite!
    Did you have any issues with the thread from the stock screw that goes through the stock plastic handle/lever & into the aftermarket valve?
    Thanks for posting your success story!!
    I have been looking at sourcing a similar looking valve:
    https://www.aliexpress.com/item/New-...2d102e0ecnC2uF
    high pressure, high temp (180c) Stainless steel.
