Results 1 to 2 of 2
Thread: Sunbeam em6910
    Aug 2018
    1
    Sunbeam em6910
    Hi, i took the steam wand of a em6910 and it has two washers, i cant get it back in, is it meant to have two washers?. Thanks for any help.
    Senior Member Xanthine's Avatar
    Sep 2014
    S.A. - South Coast
    213
    The swivel ball at the top of the steam wand has a cupped nylon sealing washer and a thin steel washer on top. Then comes a strong spring which can make it difficult to start the threaded nut which holds it all together.
    You could perhaps undo the hot water arm and compare that - it should be the same setup.
    Trev
