Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By MrJack
Thread: Breville BRES870XL lack of pressure
    Sep 2018
    3
    This machine needs to find resistance in the coffee. If the portafilter is not fully topped and strongly compressed the pressure will remain low.
    It's best to fill it up to 3/4s and compress it, then top it high and compress again to the point that will require pressure again to place it in the lock.
    Also grind the beans fine, two or three measures from the maximum.
    I was having problems for months with the needle not moving at all or barely until almost accidentally I found the right amount of coffee and resistance required. Now the needle moves more than half of the arch. This machine likes resistance.
    Nov 2013
    1,359
    That sounds like massively overdosing to compensate for not being able to grind fine enough. Better advice would be to grind finer or shim the grinder if needed and dose the recommended amount into the basket.
    Oct 2011
    1,376
    Quote Originally Posted by aranala View Post
    That is how ALL espresso machines work. Pressure is the result of the resistance to flow (whether you have a pump machine or lever machine).
    Apr 2017
    115
    You can also jiggle the portafilter as filling to achieve the same result.
