Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By level3ninja
  • 1 Post By Jackster
Thread: EM6910 Leaking after replacing collar and seal
    Feb 2015
    7
    Hi guys. Firstly i would like to say thanks to anyone who has ever posted about the EM6910. I have visited this forum countless times over the last 7 years for EM6910 troubleshooting and you have all been an immense help.
    I have now ran into a leaking issue of my own that i can't seem to fix. I have replaced both the group head seal and the collar and yet it is still leaking. The collar and the seal are both seated correctly and the machine including all parts is immaculately clean.
    The group handle locks in nicely at around 530-600 and my coffee is dosed and tamped accurately (not touching the shower screen at all).
    The only thing i havent tried is adding a shim; i am happy to try it if someone thinks i should, i had just ruled it out since the seal and the collar are brand new, my 2 group handles arent too worn, and they both seem to lock nice and tight into the head.
    I have always got a very tasty coffee from this machine. Around 45ish gram yeild over 30ish seconds from 18ish grams in, and even now as it pisses out water it still pulls a fairly nice looking shot haha.
    The water leaks from around the back of the group handle.
    If anyone has any additional advice or ideas i would be super grateful. I am also happy to take it to my local repairer (either espresso fix in Balwyn or Ellis Electrical in Dandenong) which is my last resort.
    Thanks in advance guys.
    Edit: i just tried making a shim. The group handle locked in around 700 and the leak was just as bad if not a little bit worse.
    Edit 2: here are some photos of the new seal, the 2 shower screens, the group head, and the whole lot reassembled. Let me know if you can spot any errors.
    https://www.dropbox.com/sh/ff4n1jx1c...3AEgWRNza?dl=0
    Senior Member Xanthine's Avatar
    Sep 2014
    S.A. - South Coast
    213
    Just a couple of thoughts-
    (1) Check the rim of the basket - it could be cracked or split
    (2) Are you sure the new collar is the correct one for your machine and pulled up tight against the thermoblock?
    (3) Is the water coming from the seal area and not a broken or cracked thermoblock pipe above?
    Trev
    Feb 2015
    7
    Quote Originally Posted by Xanthine View Post
    Trev
    Hey Trev, thanks for hitting me back.
    (1) The rim of the basket looks fine. Although that is my only basket and it is one of the things i have called into question as i use that in both of my group handles. The shower screen could also be called into question but it looks completely fine.
    (2) the collar is definitely correct, exactly matches the one i have replaced. It seated really nicely and all the screws are done back up super tight.
    (3) From what i can see it is coming from the seal. The leak comes from between the collar and the group handle and doesn't seem to start start until there is pressure.
    Thanks for the brain storming mate. I spoke to espresso fix today and Alex there recommended i try a full blind basket just for 5 - 10 seconds to see if it leaks with the blind one. That should rule out my basket or dosing if it still leaks. I am going to borrow a blind basket from work tomorrow and try it tomorrow night.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,403
    Quote Originally Posted by Fingman View Post
    Do the test with the blind basket very carefully as the machine doesnít have an OPV. Itís not a bad idea though so worth a try. Youíll only need to wait those couple of seconds until pressure has built up as itíll leak straight away if itís going to do so. If this still shows up a leak take the gasket out and inspect it closely. Thereís been instances of brand new silicone seals having splits in them. Iíve seen it on a smaller Sunbeam gasket and it created the problem youíre having so this is what Iíd check for first. Good luck.
    Sep 2014
    S.A. - South Coast
    213
    If the above suggestions don't produce any results try-
    (1)Removing the seal and spinning it 180deg
    (2)Packing the back half of the seal groove with one or more semi-circular cardboard shims.
    Feb 2015
    7
    Do the test with the blind basket very carefully as the machine doesn’t have an OPV. It’s not a bad idea though so worth a try. You’ll only need to wait those couple of seconds until pressure has built up as it’ll leak straight away if it’s going to do so. If this still shows up a leak take the gasket out and inspect it closely. There’s been instances of brand new silicone seals having splits in them. I’ve seen it on a smaller Sunbeam gasket and it created the problem you’re having so this is what I’d check for first. Good luck.
    I finally got to try with the blind basket today. After the preinfusion squirts, the moment that pressure built up it leaked everywhere.
    Once it cools down i will pull the seal out again and have a closer look at it to make sure i havent missed anything.
    The one concern i have is that it was leaking before changing to the new seal. Thats the whole reason i did this major service. So i am wondering if the issue is something completely different that i am missing.
    Feb 2015
    7
    I will give these a go too. Cheers!
    Sep 2013
    2,403
    Iíve had a similar issue once and it turned out to be a cracked pipe coming from the back of the thermoblock (the one that goes to the 3-way so it makes sense that it doesnít leak until thereís pressure). It couldíve be repaired as itís quite small and itís copper so I replaced the whole thermoblock.
    Feb 2015
    7
    Ahh okay. I might have to open it back up and have another look.
    Did your water come from between the group handle and the collar?
    When i had it opened last week the internals didnt look wet or water logged in any way, i assume a leaking pipe would leave some evidence.
    Definitely going to have a look when i get a chance to strip it down again. Thanks.
    May 2013
    154
    With my BES900, when I replaced the OPV and the brew pump - I was able to run it with the lid off - keeping well in mind that you have exposed 240V terminals around there so extreme caution is a must.
    This may be an option for you too - as a "look but don't touch until unplugged" with your problem.
    Sep 2013
    2,403
    Yes it leaked around the collar and as Iíd just replaced the collar I thought I must have put it back together wrong. I took the thermoblock out again to check the assembly and thatís when I found the cracked pipe.
    Aug 2013
    Rockingham W.A.
    1,505
    Before you pull it apart, try making a basic gasket (or three, if more is needed) out of thin card (cut it out the same size as the top of the seal) and use it as a spacer / packer. Unless it is a cracked pipe or similar (sympathy to leroyc - that would be a PITA) mostly 6910 / 7000s just need to get the clearance adjusted correctly. One new 7000 had three (SB "special silicon?") spacers under the seal from the factory. That would have to be 3mm of extra spacer.
    Hope this saves you some grief.
    TampIt
    BTW - if it works, sorry, you did not need to replace the collar either...
    Sep 2013
    2,403
    Yes I agree with TampIt - make sure youíre getting a proper seal before you go pulling the machine apart. Pull the gasket out and check for splits. If it looks ok then add some spacers as suggested above to make sure youíre getting a seal. If it still leaks after this then itís something else....like a cracked pipe or loose fitting.
    Junior Member Shortie's Avatar
    Oct 2017
    13
    Leaking solved?
    Solved? It would be great to know you got it sorted and how.
    Oct 2019
    1
    Quote Originally Posted by Shortie View Post
    Hi Shortie, not sure how the above issue was resolved but I recently had the very same problem, I bought new seals hoping to resolve it and the problem persisted, turned out that I had caused the problem myself after giving my machine a thorough clean I had removed the shower head and re-attached with the screw and not knowing how much to tighten it and being afraid that I might over tighten I had only screwed it in with a moderate tightness, what I did not realise was that the screw actually pulls the shower screen and the seal in fully and by not tightening it they were slightly higher than they should have been the and the brew head was not properly engaging. I should have tweaked earlier because the brew head would sometimes undo itself under pressure and I had wrongly assumed it was because my machine was worn being 5 years old. After buying new seals and having the exact same problem I finally twigged that maybe the screw needed to be fully tightened down to make the brew head engage properly so I tightened it up and hey presto ! Leak solved and the brew head no longer wants to work its way loose !
    I make on average 3 cups of double espresso every day and have done so for at least 5 years, I clean my machine regularly and it still operates like brand new.
    Feb 2015
    7
    Hi guys,
    Sorry for the later reply, this took so long to resolve, i put up with a leaking machine for so long and finally have it fixed as of a month or 2 ago.
    It turned out that there was a small crack in one of the pipes into the thermoblock. We figured this out because the water was clean so we knew that it had not yet touched coffee. Alex at espresso fix in Balwyn replaced it for me and he believed it had fixed the issue.
    When i got it home and used it it still seemed to leak but not as bad, and only very intermittently, some days it wouldnt leak, other days it would. After putting up with it for a couple of months I took it back to espresso fix again because I was done with looking at it. As it then turned out, with the new collar i wasn't actually pulling the group handle tight enough. With my old collar I only needed to tighten it just past 90 degrees, and nowhere near as tight as it could go, Alex at espresso fix said that i was lucky to have not had to tighten it as much with the old collar but from his experience most em6910s require the handle to be pulled as tight as possible, which is why everyone goes through collars every couple of years. My first collar lasted nearly 8 years, crazy.
    Anyway, I now pull it as tight as it possibly goes, which i dont like because i can tell it is wearing the collar out, but it no longer leaks, and i have bought myself time before having to replace the machine.
    Thanks everyone for your help and input, appreciate all the advice from this community.
    cheers!
    Nov 2013
    1,996
    You could always use a spacer above the group head gasket to reduce the force on the collar. Cornflakes boxes are highly recommended, though other cereals may also work.
    Dimal likes this.
    Nov 2017
    Maddington, Perth. Wa
    1,112
    For others that have had similar issues, I have found that there gets a heap of coffee oils lodged up in the groove above the group head seal. So the water makes it up and over the seal. Need to remove seal and scrub the groove clean.
    Dimal likes this.
