Results 1 to 4 of 4
Thread: Cleaning and descaling Gaggia Factory
    Jan 2006
    9
    I have a Gaggia Factory which was given to me last year and after several months of use think it would be good to clean and descale it. The instructions I have found all relate to machines with pumps, not a lever operated one like the Factory. Can anyone help with cleaning/ descaling instructions for this machine?
    Dan
    Nov 2006
    1,673
    Re: Cleaning and descaling Gaggia Factory
    There is a product called cafetto that you can get from coffeeparts or any good espresso machine suppliers or the site sponsors.
    A bottle will cost you about $24 depending on where you get it but it will last you a long time. Follow thge instructions on it. Basically you just run it through the machine followed by flushing plenty of water through.
    Whatever you do - do not use citric acid on your machine as Gaggias have aluminium boilers and citric acid will kill it dead.
    I hope this helps
    Mar 2004
    42
    Hi Dan,
    Just finished a clean of my Factory, basically I took the group head and steam wand apart, wash all the parts in clean water, wipe off, lub and put them back. Took about 1 hr to do, tedious but not difficult. I have had a hard time trying to find food-grade lub, finally found a place in Sydney that sells parts and lub.
    You might want to look around the net for some instructions and diagrams if youre not familiar with you Factory. It is much the same as the Pavoni Professional. Hope this helps.
    slowpod
    Jan 2006
    9
    Thanks slowpod
    I have done as you advised - not too difficult at all :).
    As for lubrication I used Doustgrease which is non toxic food equipment grade grease good up to 190 degrees C. I got in the plumbing section of Bunnings.
    Dan
  1. tips for leaving on a la pavoni/gaggia factory (g106/g105) all day
    By cain666_4u in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th June 2011, 01:16 AM
  2. Gaggia Classic descaling
    By richard_s in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st August 2010, 10:06 PM
  3. Gaggia Classic Descaling
    By T.D. in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th October 2009, 08:04 PM
  4. Gaggia Factory - Help with repair please
    By Ornatipes in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th January 2009, 08:11 PM
  5. Parts for Gaggia Factory - Please Help
    By Ornatipes in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th January 2009, 10:03 PM
