Results 1 to 25 of 25
Like Tree21Likes
  • 5 Post By Dimal
  • 1 Post By nickrauksts
  • 5 Post By nickrauksts
  • 1 Post By Yelta
  • 1 Post By Jackster
  • 2 Post By Yelta
  • 3 Post By nickrauksts
  • 1 Post By noidle22
Thread: Bezzera BZ99 Issues
    May 2015
    Kingaroy, Queensland
    33
    Bezzera BZ99 Issues
    My beloved BZ99 has started playing up a few days after descaling.
    The machine is heating very slightly but 60 minutes after start up the group head is only warm, I have no steam and no hot water. I can draw water out of the group head, it's warm (not hot though) at the start but then just room temp afterwards and does not heat back up to warm temp. This started 4 days ago. 2 days ago the machine stared up and worked perfectly. After that it hasn't worked again since.
    I'm hoping that it's just the heating element? Any ideas would really be appreciated.
    16,202
    G'day Nick...
    Could be down to a stuck-closed Anti-Vac Valve.
    With the valve closed before heating, the air pressure builds up in the closed boiler prematurely shutting power to the boiler. With the power Off and unplugged from the socket, remove the covers and then identify the valve. Remove it and then carefully disassemble and clean, then reassemble (with a new O-Ring if required) and refit to the boiler.
    The Anti-Vac Valve fixture is circled in Red and the Valve itself is circled in Blue on the attached PDF. The boiler depicted is not identical to your BZ99 but the valve fixture should be very similar.
    Hopefully everything will now be back to normal and you can start hitting espressos again.
    Attached Files Attached Files
    May 2015
    33
    Thanks for getting back to me Mal,
    I'm at work this morning so will see if this fixes the problem when I get home. Fingers crossed that it does the trick
    Dimal likes this.
    May 2015
    33
    G'day Nick...
    Mal, just wanted to say thank you for the advice.
    Removed the Anti-Vac Valve and gave it all a clean and wash out, there was a bit of crud hanging about so hoping that was the issue. Started the BZ99 up, anti-vac was open and closed off at about the 4 or 5 minute mark. Produced a great shot from some new beans I've only been able to have with an aeropress. Tested the steam and hot water, both working as should be. I'll go with a tentative problem solved and hopefully the machine does the same tomorrow morning before work
    Nick
    Dimal, Yelta, inorog and 2 others like this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,134
    Quote Originally Posted by nickrauksts View Post
    Nick
    Good stuff Nick, Mal's a pretty clue'y/helpful bloke, let's know if the fix holds up in the AM.
    16,202
    Aw shucks Yelta, thanks for the complement.
    Most welcome Nick. Hope it keeps on keeping on...
    Nov 2017
    Maddington, Perth. Wa
    516
    Mal is certainly a brains trust member on here. A Guru!
    May 2015
    33
    Couldn't agree more, don't know how many hundreds of posts/comments I've read from Mal.
    Unfortunately the BZ was playing up again this morning. Started up, boiler drew water and I could hear the boiler heating. Anti-Vac was open and closed off at around the same time (4 or 5 mins) as yesterday arvo. Interestingly just as I went to make my espresso the valve re-opened (around 40 mintues from startup) and stayed open which didn't happen yesterday.
    Group head was really hot but water definitely wasn't at brew temp and no steam or hot water. I ran water theough the group, boiler drew more water but couldn't hear the boiler reheating at all.
    Wondering if I should order a new anti-vac valve and see if the problem persists after that as it's pretty cheap anyway?
    Jun 2009
    Moonta SA.
    6,134
    Morning Nick, bad luck the fix didn't hold, a new valve would certainly be my next step.
    Dimal likes this.
    Nov 2017
    516
    Coffeeparts has one that plumbs into drip tray so it doesn't sputter about under the hood of your machine.
    Or is it espressoparts... Site sponsor anyway
    Dimal likes this.
    May 2015
    33
    Quote Originally Posted by Jackster View Post
    That would be great, is this the one: https://www.coffeeparts.com.au/61896...__store=online
    If thats it do I then just run a hose from the top to the drip tray?
    16,202
    Yes mate...
    That would work well.
    Should last a long time too and probably serviceable as well.
    May 2015
    33
    Will order it today, hopefully will have it by Friday and will then have coffee on the weekend
    Dimal likes this.
    Jun 2009
    Moonta SA.
    6,134
    Hope you have better luck than I have with Auspost of late, bloody hopeless.
    May 2015
    33
    Oddly enough Aus post have been good to me lately considering the xmas period.
    Most of the time it takes a few days to get things from Brisbane and I'm only a 2.5 hour drive away.
    Jun 2009
    Moonta SA.
    6,134
    Wish I could say the same, 1 package lost and another took almost a month to travel Newcastle to Moonta SA.
    May 2015
    33
    That's pretty rubbish, was it delivered on horseback?
    So I have put the new Anti-Vac Valve on. Turned the machine on.....40 minutes later the valve re-opened like it has been doing. Back to square 1 unfortunately. Any other ideas?
    Senior Member artman's Avatar
    Jun 2006
    2,288
    Is it re opening due to drop in pressure in the boiler? This should really be the only reason it is re opening. It is a simple device (as you have probably worked out takeing the old one apart), the pressure in the boiler pushes up the centre shaft and it seals the boiler. as an aside, take your old one apart and get a few new o rings for it from a bearing shop or similar, only a few cents, and you will have a stanby vlave ready for next time. Of the ones I have seen fail, its the o ring that perishes.
    When the valve pops open, are you getting any steam or can you see the boiler pressure on the gauge? If the anti vac valve pop open, logic would indicate that the boiler has lost pressure and if you dont have any leaks (which should be obvious) then perhaps the pressure stat and/or contacts are shot. ie The boiler water is not keeping hot enough to maintain the pressure.
    You could test it in several ways depending on your tinkering ability. If the BZ99 is like most machines, it is a simple diaphram that gets triggered by the boiler pressure to mechanically flick over a set of contacts. YOu could remove it and check/clean the contacts, hook up a pressure source (syringe works well) and check it triggers (tee in a guage to check at what pressure) and measure continuity/resistance across the terminals.
    May 2015
    33
    Not too sure why it's re-opening. Today when I tested it the valve didnt close at any point. From what I have been able to observe at the moment if the machine draws water upon startup i do get some pressure build up before the valve re-opens. But if the boiler is already full on startup not much happens apart from a very slight heating up of the group head and boiler, not enough to close the valve though. I can hear the slightest of sounds coming from the anti vac valve after it does close up but I swear I have always been able to hear this?
    My tinkering ability does not go into the electrical side of things and I definitely don't think I'm competent enough to tinker with 240v.
    I'm thinking I need to get it to the shop I got it from in Brissy (not a site sponsor) next week and get them to have a look at it.
    Jun 2009
    Moonta SA.
    6,134
    Bad luck Nick, as you suggest in your latest post, I suspect time to visit your local repairer.
    artman and Dimal like this.
    May 2015
    33
    I think so. I have booked in for Monday/Tuesday, hoepfully they can get to the bottom of it without too much expense. I want to upgrade sometime this year so not overly keen to spend too much on diagnosis and parts.
    Dimal likes this.
    May 2015
    33
    I've reveived an update on my machine. They have replaced the new anti-vac valve i installed and the issue is now resolved. Apparently the valve that I bought is too big? I would still like to find some sort of protection for water sputtering out the top but glad the fix is not something major.
    Dimal, Casa Espresso and JMcCee like this.
  23. #23
    May 2015
    33
    Alrighty, got the machine back yesterday and it's still not working. Machine was bench tested before it left and reported to be working just fine. The latest email I have is now suggesting there were multiple faults and only one has been rectified (anti-vac valve). Suggested additional faults are a failed pressure switch or faulty control board. This means I would have to send the machine back to be looked at again and fork out more cash to get her running. Not overly keen on spending any more money as I spent over $300 for the service, parts and extra labour to fault find and fix the fault. On a $1000 machine that's getting pretty close to my limit I think. Any thoughts on the suggested faults or anything else I could test? Today I tried bypassing the thermal block as they suspected a faulty contact, no luck.
  24. #24
    Mar 2012
    Bathurst
    1,019
    Damn, take it somewhere else if you can. They clearly don't know what they're doing.
    Sounds like they're closer on their latest guess. I would be suspecting a faulty power relay on the control board, or, a faulty pressurestat switch.
    These can be component level repaired by a competent technician but given the age of the machine, a completely new control board and updated pressurestat may be a better option. The price will be high though, component level will be much cheaper but it just depends if you can find someone who will do it.
    Dimal likes this.
  25. #25
    May 2015
    33
    Quote Originally Posted by noidle22 View Post
    Yes I was a bit disappointed with the outcome considering they're an official Bezzera distributor. Might contact a few other places in Brisbane this week and see if I can get some quotes. The few times in the last few weeks the machine has at least started to heat up have hear the clicking on ans off, would it be more likely to be the control board if this is the case? I have noticed the anti vac valve tends to spit out a bit of water close to the GICAR as the valve closes.
