Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By level3ninja
Thread: Breville Barista - Double shot volume?
    Feb 2018
    31
    So, if the established shot size for a 'standard' (i.e. 58mm) basket is 30ml (or, 60ml for a double), what shot size should I looking to be pulling from a the Baristas 53mm basket? Obviously will not hold as much coffee (max 18gm, maybe...?)
    Apologies if I'm getting any of the above info incorrect.
    Thanks in advance
    R
    Senior Member woodhouse's Avatar
    Dec 2016
    391
    from an 18g dose? whatever volume 36g-54g ends up being.
    Nov 2013
    1,998
    Use a set of scales to determine your dose in the basket and then use a ratio to determine the yield you should be getting in the cup. Woodhouse is suggesting a ratio of 1:2 - 1:3, I would suggest somewhere around that, even slightly less than 1:2 might be ok but go by taste.
    woodhouse likes this.
