Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Jackster
  • 1 Post By fatcat
Thread: Nuova Simonelli Oscar 2 flow stop during a shot
    Aug 2012
    15
    Nuova Simonelli Oscar 2 intermittent flow stop during a shot
    This machine is approx 18 months old, it has an OPV fitting.
    Recently I have been noticing some inconsistencies in my shots and pour times. I thought it was the new beans I am using initially.
    I then did some diagnosing and some really long test pours. I am thinking that either air is somehow being introduced or the pump is on the way out (harder to believe being this old)
    https://www.youtube.com/watch?v=F9s66yDGCmA
    https://www.youtube.com/watch?v=FziX-gVZEjk
    Sometimes gaps are longer and shorter, sometimes not at all.
    Nov 2017
    Maddington, Perth. Wa
    1,098
    You need further diagnosis. Block the opv return and test, and disconnect pump output and compare flow to group flow.
    Time for 30sec, flow should be around 300ml.
    The pump non-return valve may have a bit of something in it. Mine had same- inconsistent pressure and flow, I fixed it, but ended up putting a new pump it it.
    (I have some for sale in for sale section...)
    Aug 2012
    15
    You fixed it before the new pump went in? I will try like you said.
    Nov 2017
    1,098
    Yes, I cleared whatever was in the pump, and it was better for a while, but the issue returned and I replaced pump.
    matth3wh likes this.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    1,011
    Following along to watch as I suspect Iíve seen this behaviour on my home machine but it has gone away or am not seeing it with my current regimen.
    Aug 2012
    15
    Quote Originally Posted by matth3wh View Post
    Swapping pump seemed to fix the issue so far.
    Dimal likes this.
