Results 1 to 5 of 5
Thread: Sunbeam em7000 fault
    Apr 2019
    3
    Hi all first post, looking for advice on my em7000. Brought my machine back from Tassie and unfortunately the thermal block pipe snapped in the move. Ordered a new one from aus, fitted fired up brilliant. Started testing all good until tested hot water, dumb *** me hadn't tightened up the nut properly. Switched off tightened. Powered on the panel lights, it beeps but weak and all lights stay on with no gauge movement. Any reset procedure or pointers would be well appreciated. Txs in advance 👍
    Nov 2013
    1,811
    So did water leak everywhere inside the machine or what? Why do you think it stopped working?
    Apr 2019
    3
    Not as much as when I discovered the broken pipe, tablespoon at most.
    Nov 2013
    1,811
    So you noticed the loose nut, turned the machine off, tightened nut, turned machine on and it's pretty much unresponsive?
    Apr 2019
    3
    Thanks for the inputs, stripped and removed the boards contact cleaned everything left it for 24hrs and had my first decent coffee in a long while. Love the site lots of great information ��
