Results 1 to 8 of 8
Thread: EM 6910 steam wand not working - can hear pump but no steam
    Sep 2017
    49
    Hi all - I'm trying to get a 6910 working properly. I was given it - apparently not working at all - but I managed to get the hot water and the main coffee machine working - I think it just needed priming. I was hoping the steam wand was the same but apparently not. I took the wand off and ran vinegar through it and rinsed it - water going through just fine. I also took the knob off and removed the other nut bit and didn't notice anything amiss - clicky switch thing at the side seemed ok.
    So now I wonder what next? I can hear the pump. It is regular but quieter than my other 6910.
    Thanks all!
    Nov 2013
    1,387
    Is the steam thermoblock heating?
    Sep 2017
    49
    Good question - how could I tell? Does the steam want get hot at the base if it is working?
    Sep 2017
    49
    Not sure if this tells us anything but the base of the steam wand bits (the nut etc) is getting much hotter than the hot water tap that I didnít run this morning?
    Nov 2017
    Maddington, Perth. Wa
    929
    Thermoblock sounds to be blocked. Plenty of threads on here about how to descale the steam side of these machines. But it might need replacing.
    Nov 2017
    929
    https://coffeesnobs.com.au/brewing-e...el-em6910.html
    Obviously you have read the replies to your other thread.
    Run it longer with the vinegar through it.
    You will need a sparky to pull it apart of that doesn't work. Maybe a heavier descaler and manually running pump, or reverse flushing thermoblock. Or remove and replace thermoblock
    Sep 2017
    49
    Quote Originally Posted by Jackster View Post
    Thanks - how do I manually run the pump and reverse flush thermos lock? Any previous threads on this?
    Do you mean run the steam wand longer with vinegar in the tank? Currently there is a rythmic quiet pump noise but nothing coming out, no water even.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,229
    Quote Originally Posted by latte1978 View Post
    Iíve just posted on your other thread - donít run the pump for longer, rather run it repeatedly every few minutes for a few seconds at a time.
