Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Meljmac
Thread: EM 6910 Making noise but no action
    Jun 2016
    7
    Hello
    After not using my 6 year old machine for a month or so it's not working. It makes noise but nothing comes out. The top of the tampered coffee is damp when I remove it. The steam wand starts producing steam for a few seconds and then stops.
    Any tips?
    Aug 2013
    Rockingham W.A.
    1,438
    Quote Originally Posted by Meljmac View Post
    Hello
    Any tips?
    G'day Meljmac
    If you are lucky it is just an airlock - the older 6910s are prone to them when sitting around (I still have two of them).
    Turn the machine on, wait until all idiot lights suggest it is ready and then try the hot water tap. If it splutters for a while and then gives a hot water stream you can sigh with relief and try the main group (without anything in it) and that should also flow hot water freely. Then you can try the steam and see if that clears.
    If that does not work, I suggest you work out whether you wish to tinker or send it to a repairer...
    Hope this helps
    TampIt
    Jun 2016
    7
    THANK YOU! Your trick worked. So grateful!
    Quote Originally Posted by TampIt View Post
    G'day Meljmac
    Hope this helps
    TampIt
    level3ninja and Simplyhuman like this.
