Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By noidle22
Thread: Sunbeam EM7000 hardly moving needle AND drip tray gradually filling with water
    Dec 2015
    23
    Hi All
    so it's weird, the pressure needle hardly moving like we haven't tamped coffee hard enough
    adjusted grinder, made no difference
    AND
    i just noticed for the 2nd time that the collection tray is full of clear water but there's no sign of where its coming from
    any ideas please?
    Dec 2015
    23
    I'm thinking its a blockage, the water pressure spill off flows into the drip tray?
    Jul 2019
    3
    EM 7100 no pressure at group head- ends up in drip tray
    Hello,
    7100, water comes out of the group head if no grinds are in the basket, if there is a dose in the basket the water all ends up in the drip tray and no pour delivered.
    I have tried very loosely tamping the basket, no joy. Water does come out of the group head without a handle present at what appears to be normal volume.
    So essentially with a basket with normal grind tamped normally the water simply ends up in the drip tray. I have done a clean with the rubber cap and some good quality cleaning crystals and it did build up enough pressure to do this correctly.
    Am I missing something? Any clues?
    Cheers all
    Tony.
    Dec 2015
    23
    What the? Appears our 2 posts are linked
    we seem to be having exactly the same issue
    With no head inserted the water flows out normally, once coffee is in the group head it was getting some water/coffee through but very week and the needle hardly shifted
    i'm thinking its a blockage somewhere as built up pressure is releasing the water inside the unit somewhere into the collection tray
    I CANT THINK STRAIGHT i'm coffee deprived!
    Jul 2019
    3
    I have cleaned mine in every way I know. Water comes out of hot water spout. Steam wand is fine, is just simply the water does not pressurise the water that is coming out of the block, instead it is ending up straight in the drip tray. Same?
    Mar 2012
    Bathurst
    1,204
    The solenoid valve that opens to release water pressure on the puck once the shot has finished is constantly leaking when under extraction pressure.
    You will need a new solenoid valve. This applies to both posts here.
    Dimal and Tame9cruet like this.
    Jul 2019
    3
    Quote Originally Posted by noidle22 View Post
    Thanks for your help. Due to issues with the acquisition of parts, the Hobart repair guy has pulled the pin on sunbeam.
    They are going to send an eparcel form to send it away for repair.
    Dec 2015
    23
    "You will need a new solenoid valve"
    cool, is there a part number that you know of please?
    something I can do myself? [ex plumber ]
    Dec 2015
    23
    Maybe this, I've inquired with Big Warehouse Spares
    SUNBEAM EM7000 EM7000 SOLENOID VALVE ASSY - EM7000
    Part Number 1736121
    Appliance: SUNBEAM COFFEE MACHINE EM7000
    Description SOLENOID VALVE ASSY - EM7000
    Dec 2015
    23
    Apparently this is the solenoid required
    Sunbeam Cafe Series Espresso Coffee Machine EM7000 STEAM REGULATOR - EM70019SOLENOID VALVE - EM70041
    Sunbeam Cafe Series Espresso Coffee Machine EM7000 SOLENOID VALVE - EM70041
    • Print
    • View full size
    More details
    ON SALE!
    $66.00 tax incl.
    Reference :EM70041
    Quantity :
