Results 1 to 16 of 16
Like Tree7Likes
  • 1 Post By artman
  • 1 Post By level3ninja
  • 2 Post By level3ninja
  • 1 Post By Dimal
  • 1 Post By artman
  • 1 Post By rodpinna73
Thread: Lelit PL41 went pop and started leaking at group head
    May 2011
    29
    My trusty Lelit PL41 went pop while I was backflushing, and water started coming out from around the group head. It popped once the pressure gauge started showing around 10 bar.
    Everything else seems fine.
    Is this just a case of needing a new O ring?
    And is the there a recommended Perth site sponsor? It looks an easy fix, but by the time I get the parts in, or might not be much more to get it done by a pro.
    Nov 2013
    1,922
    When you say "went pop" do you mean the portafilter fell out of the group head? If so did you lock it in tight enough? If the seal is getting older you may need to move the handle further to achieve the same seal.
    May 2011
    29
    No, it stayed on. The pop was just from the sudden release of pressure. If I turn it tighter, it delays it a bit from releasing the pressure, but eventually the seal gives way.
    Nov 2013
    1,922
    Sounds like you need a new group head seal.
    https://www.jetblackespresso.com.au/...oup-head-seal/
    May 2011
    29
    Yup. That's what I was thinking, just wanting some confirmation that I wasn't stupid
    Is it just that, or are there any other bits I should do at the same time? YouTube video makes it look easy....
    Senior Member artman's Avatar
    Jun 2006
    2,473
    assuming these are the same group design as the old machines, you can undo the group collar (might need thin wall 8mm socket - I ground down a spare) - 4 bolts, then the seal is exposed and easy to replace and also clean the surfaces thoroughly. These bolts sandwich the the boiler and group collar through the bottom plate, so the boiler will be a bit wobbly.
    I believe you can now get silicone seals for these.
    Dimal likes this.
    Nov 2013
    1,922
    I'd pull the shower screen off and soak it in Cafetto. If it comes off easily and cleans up well it'll be fine to reuse but if not you may as well replace it too.
    The one I linked is silicone.
    Dimal likes this.
    May 2011
    29
    Thanks all. Bits ordered from Jetblack, so I'll give it a go.
    It can't be that hard...
    Nov 2013
    1,922
    Just make sure you get rid of every last little piece of the old gasket, and and gunk build up under it. It might come off in one piece or it might come apart in your hands. Either way near enough isn't good enough when it comes to removing the old one, spend the time and do it right. Some people say to replace them every year, I usually do mine about every 2 years.
    Dimal and Javaphile like this.
    17,474
    The new Silicone Rubber one will last much longer though...
    Javaphile likes this.
    May 2011
    29
    It was serviced about a year ago, so hopefully it isn't going to be too bad under there. Assuming they replaced it of course...
    Jun 2006
    2,473
    The silicone one also dont tend to stick/bake on like the rubber ones too.
    Yes as above, good practice to clean the shower screen. Its stainless so a decent scrub should see it come up good. Once you remove the middle screw, you can gently pry it from the centre to pop it out, its often stuck in the small recess of the group.
    Dimal likes this.
    May 2011
    29
    Help!
    Got all the bits from jetblack.
    Got the middle bolt off, and the shower screen. Removed one of the bolts that hold on the next part to come off. Seems to fit a small allen key.
    The next one though is completely stuck. No chance of getting it move, and I don't want to round it off (if I haven't already)
    Any suggestions!
    EDIT: of course, after posting this, I had one more go and managed to move it. Do these screws need to be in quite so tight? Feels like the person who put these in must have been a gorilla....
    17,474
    Some photos might help, not sure which bolts/screws you're referring to...
    May 2011
    29
    It was pretty much the screw that held on the shower screen, which I had to Dremel off, and the Allen head screws that hold on the nozzle or dispersion plate under the shower screen (part MC191)
    Either from age related build up or someone much stronger than me putting them on, all the screws were a bugger to get off.
    All back together now and working. No more leaks
    Dimal likes this.
    17,474
    Quote Originally Posted by rodpinna73 View Post
    Great news...
