Results 1 to 4 of 4
Thread: Quick EM6910 Question
    Dec 2007
    16
    Hi!
    This is probably a dumb question. I am thinking of buying one of these.
    The EM6910 comes with a single-cup spout (loose), and a double-cup spout fitted to the group handle. If you use the double-cup spout but only want to make a single cup (because you dont want to go changing the spout all the time), do you need to put two cups under the spout and combine the contents? Or does it somehow only send coffee out of one of the spouts?
    Sorry, but thank you to whoever can help me.
    COFFEECHASER
    Re: Quick EM6910 Question
    That is a fair question to ask. You just put the cup under both spouts if you only want to make one drink. If you still use the double basket underneath it you will either make yourself a double shot or pull the shot early and just get the first 30ml. Otherwise you can use the single basket still with double spout.
    I hope that clears it up for you somewhat, if not ask away.
    Brett
    Dec 2007
    16
    Brett...
    Many thanks for the reply. Perfectly answered. Thank you again.
    Dec 2007
    9
    i recommend using double spout only to start, i found it easier to manage for some reason, dont know why though, good machine to get, had mine nearly a fortnight, so still learning, but makes a great coffee 9 out 10.
  1. Quick question regarding O/S grinders
    By Stuey in forum Grinders
    Last Post: 22nd August 2010, 11:14 PM
  2. Quick question Breville 800 es
    By maheel in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th March 2010, 08:52 AM
  3. EMO480 - Quick cleaning question
    By lawsy82 in forum Grinders
    Last Post: 10th January 2010, 11:57 AM
  4. Quick question need to prove someone wrong
    By andrew_harris88 in forum General Coffee Related...
    Last Post: 24th November 2009, 01:38 PM
  5. Quick Question
    By cuppa in forum General Coffee Related...
    Last Post: 2nd April 2008, 04:11 AM
