Results 1 to 13 of 13
Thread: Silvia double spout giving uneven shots
    Feb 2008
    7
    Hi all, Im a first time poster, but long time reader.... this site has a wealth of good information but I cant find a definitive answer to my problem.
    Ive just acquired a brand spanking new Rancilio Silvia from sponsor CosmoreX Coffee and Im managing to get some decent shots out of it but the problem I am having is that when I make a double shot into 2 cups the one under the left hand spout always ends up with less coffee in it *compared to the one under the right hand spout.
    I am pretty sure I am tamping the coffee evenly (I have a decent tamper, better than the Rancilio supplied tamper, and have been checking the tamp is level), the kitchen bench top is level and there doesnt appear to be any restriction in the left hand spout.
    Is there any thing else I should look into?
    I read on some other site that an adjustable spout may be what I need to fix this problem for good, is the La Marzacco 511672-R (as available from Coffee Parts) a suitable replacement?? *
    Is this is the solution to my problem???!?
    Jan 2008
    1,756
    Re: Silvia double spout giving uneven shots
    Hey letaage, i have the same problem.....sometimes, not always, my bench is level also, i have a pullman tamper and im tamping level, i thought it had something to do with my dosing, but the rocky doses into the left hand side of the PF, and thats the side that produces the bigger shot, so thats out......looking forward to suggestions also!
    cheers
    warren
    Jul 2007
    539
    This is a common problem with the Silvia, which many people have mentioned before.
    Yes, you can use the CoffeeParts 511672-R, but it doesnít screw up flush against the bottom of the portafilter, and faces the wrong direction when tightened up (yes, I have tried this part on the Silvia). However you can fit a washer between the spout and portafilter and it then fits fine.
    As I said, I did try that part, but I eventually went back to using the standard Silvia spout. To fix the problem I just raised the one side of the machine slightly. In my case I needed to raise the left side, but youíll need to raise the right side. Or another solution that Iíve read on here before is to file the inside of the spout to encourage more flow out the (in your case) left side.
    regards,
    Bill
    May 2007
    Perth, Western Australia
    3,155
    Mine is the same but I have learnt to live with it, if Im doing two singles I just remove one and top up the other near end of shot.
    Feb 2008
    7
    Thanks for the replies, I guess Ill have to try raising one side of the machine slightly.
    I dont have the dexterity just yet to go the swicheroo with the cups with everything else thats going on when pulling a shot, and tilting the machine should also be a lot cheaper than an adjustable spout!
    But if tilting the machine doesnt work I might have to look into an adjustable spout. And a washer to make it fit properly!
    Apr 2007
    596
    The spout cross hole on mine was drilled at a angle :( hence the uneven flo, attacked mine with a dremel, but it still needs a bit more to even it up.
    sdg
    sdg is offline
    Mar 2008
    368
    Hi vicroamer,
    did the "attack with the dremel" work in the end? I have the same problem, and an SO with a dremel, so would love to know...
    Apr 2007
    596
    Still havent finished it off, I have to borrow dremel again. It does work, just a matter of balancing the flow, do a couple of drippy test pours at the end to confirm flow is balanced.
    Senior Member clubbi4's Avatar
    Feb 2008
    105
    Hi Letaage, I have had this problem before on commercial machines, i find that some spouts are not made even, level. All you need to do is file away on the side that is pouring less until it pours even. I have done this on a number of spouts and it works beautifully. You can also buy a universal spout and see if that is made more even. ;)
    Senior Member E-Gene's Avatar
    Sep 2007
    Melbourne, Australia
    323
    Im eliminating this problem on my machine by getting a naked portafilter.
    sdg
    sdg is offline
    Mar 2008
    368
    Are there any of our sponsors in Melbourne who supply a naked PF for Silvia?
    14,665
    Quote Originally Posted by simone link=1204445637/0#10 date=1205157212
    Hi Simone,
    Try Ofra and Renzo at DiBartoli. Even with postage, their naked p/f is one of the keenest priced and best finished in town. ;)
    Option 2 is to grab an old Silvia group handle from one of the old Silvia suppliers in Melbourne and chop it down yourself.
    Good luck!
    Sep 2007
    323
    Try Coffeeparts http://coffeeparts.com/accessories/nakedpf.html. One of our sponsors.
  1. Replies: 6
    Last Post: 25th December 2012, 12:02 PM
  2. Replies: 6
    Last Post: 2nd February 2010, 07:56 PM
  3. Silvia Double Spout and uneven pours - again
    By nikkikirks in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th March 2008, 07:14 PM
