Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By Andy
  • 1 Post By Journeyman
Thread: Removing portafilter spouts Sunbeam EM6910 (etc)
    Mar 2005
    2,165
    I recall some EM6900/6910 users reporting problems getting their portafilter spouts off in order to remove their Graeme (black plastic insert for those who dont know the lingo ;)) and I agree that out of the box theyre far too tight to undo by hand. Ive had to do this several times to convert a bunch of new units to bottomless ones, and the easiest way I found to do this was lie the shaft of a big screwdriver in the channel of the spout, which gives you two long levers (the portafilter handle and the screwdriver) to apply plenty of force and you can just rotate the two (anticlockwise of course) and unscrew the spouts. This prevents damaging the outside of the spouts with vice jaws or the inside with the end of a screwdriver or something. Just make sure the screwdriver doesnt slip out.
    This would apply to any other spouts of a similar design.
    Hope this helps someone.
    Mar 2008
    437
    Re: Removing portafilter spouts Sunbeam EM6910 (et
    I broke the entire spout off awhile back so be careful.
    Oh and speaking of spouts, any idea how to glue one back on? Food grade heat resistant metal adhesive?
    Ali
    Ali is offline
    Apr 2008
    91
    Thats how I got mine off Greg, although I wrapped the screwdriver in a thin rag as I wanted to be sure it didnt affect the metal. *I think it has some kind of glue on it to keep it tight. *The instruction book says to use a piece of dowel but I didnt have any the right size.
    Ive found that the spout is now fairly loose to get it back in position to pour into 2 cups though.
    I havent attempted to remove the black insert yet (why is it called a Graeme?).
    Senior Member MeanzBeanz's Avatar
    Apr 2008
    Perth
    111
    Hi Ali
    The manual says they use locktite when it is manufactured and force may be required. Some CSs report success heating the area first to loosen the locktite. Try leaving it in boiling water for a while.
    I had difficulty removing mine to remove the black plastic insert. Apparantly it is there to keep the coffee from hitting a cold pf (I pre heat mine by flushing.) Try using a pointy threaded bolt of the correct guage to screw it in and remove it.
    Mar 2008
    437
    After removing the spouts, you should see the black piece of plastic extending out of the PF, squeeze the two sides and push it straight in.
    At least thats how I did it I think....
    Mar 2005
    2,165
    Quote Originally Posted by Gavin1 link=1212238158/0#1 date=1212241366
    Wouldnt have a clue, youd need to solder it probably in something food grade thats compatible with the base metal, so good luck. Ive got plenty of these as a result of this project so let me know if you want a replacement.
    Graeme, its just a term someone came up with because the thing didnt have a name. Its so pointless its stuck! ::)
    10,496
    Quote Originally Posted by Thundergod link=1167134124/30#38 date=1209124004
    The name was actually suggested by the user called DIG.
    You can read the whole story in the original post here:
    http://coffeesnobs.com.au/YaBB.pl?num=1188978543/4#4
    10,496
    Yesterday I took the graeme out of the PF that came with the new 6910(I use the old one that had already been modified).
    I had no trouble at all undoing the spout by hand and the graeme came out without a struggle with no more than a firm push with a spoon handle.
    Ali
    Ali is offline
    Apr 2008
    91
    Nope - still cant get the graeme out. Tried the spoon handle. Any other suggestions?
    Apr 2007
    1,687
    Blowtorch? Melt that sucker out haha....ok not helpful
    Ali
    Ali is offline
    Apr 2008
    91
    I take that back... just did it with a little persistence :)
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by Ali link=1212238158/0#10 date=1212466926
    And a little sweat
    Apr 2007
    1,687
    ...and a little heat from the Blowtorch comment ;)
    Ali
    Ali is offline
    Apr 2008
    91
    Hmmm... a melted plastic flavour to my coffee. Yum!
    Dec 2009
    140
    Hey all,
    I removed the spouts on the EM6910 portafilter handle as they were loose and to give them a clean. Now they aren't aligning properly - has anyone please got any helpful hints as to how to re-align them? Otherwise I might be in the hunt for a new portafilter handle!
    May 2009
    Bendigo
    1,029
    Did you remove the Graeme as well? If not maybe it is preventing the spouts from screwing back in properly? I undid mine with multigrips with cloth to protect the finish, squeezed the Graeme lugs together to push it out, then tightened the spouts to just more than finger tight and they lined up perfectly.
    Dec 2009
    140
    Hey Journeyman, thanks for your reply. Graeme is long gone!
    May 2009
    Bendigo
    1,029
    It's metal-to-metal so I am not sure what might be causing the alignment issue. 2 things come to mind - something in the gap stopping a proper tightening or cross-threading.
    Do they tighten past the correct position or don't quite reach it? Try using a stiff brush to clean in the threads of both parts. Maybe a washer as a spacer to stop the screw-in earlier to allow alignment?
    Dec 2009
    140
    Hey Journeyman,
    They tighten past the correct position which is annoying - I put some plumbers tape in the grooves and it seems to have fixed the problem - hope it won't melt into the coffee!
    Might have to look at getting a new portafilter!
    Mar 2004
    Internet
    17,020
    Blog Entries
    1
    "teflon tape" is good for a couple of hundred celsius, it will be fine with coffee.
    The other option is Loctite, it will err, "lock the threads tight" in the position you want.
    Tango likes this.
    May 2009
    Bendigo
    1,029
    Plumbers tape might melt - most of it is not for high temp application. Check what you have and if needed check the manufacturer web page.
    Tango likes this.
    Dec 2009
    140
    Thanks guys, pretty sure it's teflon tape and I just made a coffee with no dramas!
  1. EM6910 GH Spouts
    By jkarlis in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th June 2010, 01:57 PM
  2. SOLD-Sunbeam EM6910 portafilter
    By flatwhite in forum SOLD
    Last Post: 10th December 2008, 03:25 PM
  3. Replies: 2
    Last Post: 8th September 2008, 12:26 PM
  4. Silvia Portafilter - removing spouts...
    By mrmarky in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd February 2008, 02:17 PM
