Results 1 to 14 of 14
Thread: Sunbeam 6910 and dose amount
    Jul 2008
    31
    I looked for previous posts on this topic but couldnt find any (probably blind)
    Anyway, I have been enjoying my new 6910 combined with the Challenge grinder that I purchased 2nd hand from a very helpful CSer.
    My question/issue is that my 6910 has started to change the amount of water it passes through for a single dose (not using the manual button). It previously seemed to be around the 30ml level, but lately its been around 50ml or so. I havent measured it but its so much greater than 30ml its obvious.
    Before I go and adjust the amount through the programming, I am just wondering if this change is a portend to other not so good things happening. Has anyone else experienced this with their 6910?
    Also, just to give a context, the machine has only made around 30 coffees as I only use it on the weekends due to early working day starts.
    thanks,
    Justin
    10,496
    Re: Sunbeam 6910 and dose amount
    Sorry Justin Ive only ever used the manual button.
    Over how long have you noticed this change?
    My first guess would be that the coffee is staler than it was and that will cause a faster pour.
    Jul 2008
    31
    Quote Originally Posted by Thundergod link=1217992744/0#1 date=1217994801
    It only started last weekend. The coffee I used was just ground (Cuban something from The Coffee Company [excellent]) that I had purchased in the morning. I also got the same pressure (as previous) and a good pour (at least to my eyes).
    Also, I thought the single dose setting was not time but volume dependant - is this the case?
    10,496
    Im not 100% sure but the instruction manual says volume, however if you choke the machine it eventually cuts out as if it thinks it has done 240ml (max).
    There are too many variables in your scenario to be sure.
    Was it the first shot from that bag of beans?
    Have you used the same beans before?
    Are you sure the grind setting was identical?
    Id be ringing Sunbeam and running it past them.
    Jul 2008
    31
    Maybe a call is in order. *:-/
    The beans are the same as I used previously and I had only adjusted my grind slightly finer prior to using.
    I think, also, the 240ml is when using the "manual" button. I didnt think it applied to the single dose button.
    The pour was from the first and second shot from the new bag of beans. (I havent done any more)
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    945
    I have only had my 6910 for a couple of weeks but on the dose buttons I have only noticed minimal difference depending on the bean. And I mean 1-4 mls variation at most. I only use fresh beans roasted within days of use.
    Site Sponsor
    Jun 2008
    45
    Hey there JustinD,
    I deal a lot with home and office machines. All of the big names in the small end of the market and I cant begin to tell you how many in the last year I would have had to reset to the desired level. I also have the 6900 in my kitchen. I generally find that at some point or another the dosage will go out of whack. There is no reasonable explanation to this. It comes down to a general malfunction within the computers used in these small end machines. There is probably nothing to worry about! I would suggest you use the programming to reset the pour to your desired level ie. 30ml and watch it from there. However if this is to keep happening give Sunbeam a call as it could be an ongoing problem.
    Hope this helps.
    Richard
    10,496
    Justin the 240ml comment was to point out an observation of mine as to the way it works as opposed to way the book says it works.
    Maybe you should reset it to the default settings for now and just keep an eye on it.
    See page 20 of the Instruction Booklet for how to reset to default.
    Jul 2008
    31
    thanks for the comments. I will reset the little unit. I totally forgot that I could do this (or more, it just didnt occur to me). If It still happens I will report back here.
    Jul 2007
    Werribee, Victoria, Australia
    737
    Justin, you can use the program button to set the amount of extraction. Once you set the amount then you can start working out Tamp pressure,grind courseness as Thundergod said there are many variables.
    You must eliminate one thing at a time.
    Apr 2008
    24
    Maybe you should do a single dose shot with no grounds in the PF and measure how much water is being passed.
    In my experience the volume of coffee espressed by the single, double and manual buttons is only related to the tamp and appears to be on a timer circuit not a volume measure despite what the manual says.
    10,496
    So you agree with my observations.
    Jul 2007
    737
    I agree with you Thundergod. I myself use the manual button and just go by eye.
    Jul 2008
    31
    I dont disagree with Thundergod.
    Also, I did the Sunbeam class thing and we only used manual. I just like to use the single dose button while I am heating the milk.
    I havent adjusted things yet.
  1. sunbeam 6910 vs baby gaggia dose
    By kofi in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th November 2008, 09:46 AM
  2. Sunbeam 6910
    By bellmeremark in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th December 2007, 06:11 PM
  3. SUNBEAM 6910
    By ellie_belly26 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th April 2007, 08:27 AM
  4. Sunbeam 6910
    By scoota_gal in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th December 2006, 09:18 PM
