Results 1 to 7 of 7
Thread: Squeaky Silvia steam valve
    Apr 2008
    16
    After nine months of making coffee once a day my Silvias steam valve has started to squeak when I open and close it. It doesnt effect the steaming, just sounds terrible.
    Any suggestions on how I could lubricate it?
    DONT USE
    Jan 2008
    432
    Re: Squeaky Silvia steam valve
    the silvia has two different skeaks
    1 contact between the plastic knob and the insert in the stainless front face = little bit of vaso opr grease
    2 the thread inside the valve is dry
    in this case steam valve needs to be removed, dissasembled and lubricated
    graham
    May 2008
    69
    I just took mine back to get lubricated....WOW what a difference....not only did the horrible squeak go away, but its so easy and loose to turn.....
    Apr 2008
    16
    Any hints on how to get the plastic knob off?
    Jul 2008
    323
    Quote Originally Posted by LastMile link=1222489132/0#3 date=1222599609
    The steam knob just slides off the shaft with a firm pull. It has a little spring clippy thingo that holds it in place :)
    sdg
    sdg is offline
    Mar 2008
    368
    Haha -- on a new Silvia maybe ::)
    On one where the knob hasnt been removed for a while you may need 2 people, one to hold the machine and one to puuuullll!!!
    Apr 2008
    16
    Thanks guys. I used a wooden shoe horn that I had lying around to gently pry the knob off.
    A little tap grease and its much quieter. I think I will need to get the valve serviced at some stage before my warranty runs out, as its a little stiff and no where near as smooth as it used to be.
  1. Rocket Giotto Squeaky steam valve
    By chrislng in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th November 2017, 05:00 PM
  2. Does the Silvia steam valve need lubrication?
    By Arv in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th January 2011, 10:03 AM
  3. Silvia squeaky steam knob & leaking steam wand
    By Kasa in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th January 2009, 11:39 PM
  4. sticky Silvia steam valve
    By philipmach in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th January 2009, 10:00 AM
  5. Silvia steam valve squealing?
    By gregpullman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th June 2007, 01:30 PM
