Results 1 to 4 of 4
Thread: Rancilio Silvia Leaking
    May 2008
    69
    Hey,
    My Silvia is only a few months old and Ive just noticed in the last 3 or 4 days, water coming out from underneath the machine. It seems to happen when the machine is under pressure (brewing a shot).....
    Ive looked underneath the machine while brewing, expecting it to be coming out of the 3 way let off, missing the drip tray or something, but its not dripping near that at all.
    I am going to open it up to have a look but I was just wondering if anyone might know of what to look for ? If theres any known problems like this
    Thanks ,
    Ed
    Apr 2008
    Brisbane
    5,113
    Re: Rancilio Silvia Leaking
    To be sure take the panels off
    Run a shot with the blind filter and observe
    Hopefully it is just a not so tight fitting that has a slight leak and just needs nipping up
    Do it soon in case the water is dripping over or near electrical connections on the way down
    17,114
    Could be just the OPV bypass return.... Sometimes these "fall off" if they havent been fitted properly. Easiest fix is just to remove the silicone tubing from the plastic fitting that is normally attached to and fit the tubing directly over the fitting from the OPV. This may or may not apply to your Silvia but a couple of units I looked at years ago were like this...
    May 2008
    69
    No worries..
    Thanks guys..
    I"ll check it out
  1. Leaking Silvia :(
    By Armers in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th May 2012, 12:31 PM
  2. Help! Silvia Leaking Grouphead Seal?
    By azeworai in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th February 2012, 08:30 AM
  3. Rancilio S26 - Leaking Water
    By Sacred_Cow in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 5th October 2009, 08:42 AM
  4. Leaking Silvia Solenoid Valve
    By grimsby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th March 2008, 07:08 AM
