Results 1 to 5 of 5
Thread: Sunbeam flashing red light..
    Flo
    Flo is offline
    Aug 2006
    330
    Hi all. Its been a while...
    Anyway..a friend of mine has a dual thermoblock Sunbeam (hes not sure what the model number is) and just the other day it developed a problem where it is not producing steam and there is a red light continually flashing on the front of the machine. He says it pulls shots just fine but no steam.. I think the machine is a couple of years old..
    Any suggestions?
    10,496
    Re: Sunbeam flashing red light..
    There are 2 red lights.
    One on the power button and one near the water window.
    Sleep Mode
    After 1 hour of non-use the espresso machine
    will automatically switch to ‘SLEEP MODE’.
    An indication that the machine is in ‘SLEEP
    MODE’ is the light above the ‘POWER’
    button will slowly flash red. While in SLEEP
    MODE the machine powers down to 70% of
    power. After a further 26 hours of non-
    use
    the espresso machine will turn off.
    It doesnt sound like Sleep Mode though.
    It might have the 5 year pump gurantee so as the steam pump isnt working I suggest you ring Sunbeam and ask them to fix it.
    Tel: 1800 025 059
    Oct 2008
    79
    That sounds like the original problem that the 6900 Model had (if the machine is a couple of years old then it sounds like it would be the 6900, not the 6910).
    ....and yes, it will no doubt need a visit to the Sunbeam service centre.
    Jun 2007
    362
    I would say that the steam thermoblock is not heating - it is flashing waiting for it to heat up!
    Aug 2004
    306
    Theres also a flashing red light when the reservoir is empty - perhaps theres a block in the flow?
  1. Sunbeam Cafe Series 6910 - Flashing Water Light
    By tellybox in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th July 2019, 06:30 PM
