Results 1 to 11 of 11
Thread: Levetta brew pressure
    htb
    htb is offline
    Jul 2008
    163
    Hi Snobs,
    I managed to pick up a cheap Levetta the other day and am pretty happy with it. It was filthy when I got but a new shower screen, seal and lot of scrubbing fixed that.
    Anyway I have only made about four shots on it so far and have noticed that the brew pressure doesnt get over 8 bar. Should I be concerned with the pressure and if so how can I adjust this?
    The coffee also seems to be a tad hot and tastes a little bitter but this could be due to my technique (or lack of). I am still getting aquinted with this machine and its crazy steaming ability.
    May 2008
    4,127
    Re: Levetta brew pressure
    Is this 8 bar on the pressure gauge on the front? Sounds too low. Mine shows 10 bar, and that was after it was properly adjusted by Chris from Talk Coffee to deliver 9 bar at the grouphead.
    Bitter could be due to under-extraction due to under-dosing, too coarse grind or channeling. If you are in Sydney or Melb. might be worthwhile having someone look at it.
    htb
    htb is offline
    Jul 2008
    163
    Its 8 bar on the front gauge. I am aware that it will be different at the group but from what I understand its usually lower not higher.
    What effect does the brew pressure have on the shots?
    I am still experimenting with the dose, tamp etc and the shots taste okay so I am too fussed with slight bitterness at the moment.
    Jan 2008
    476
    Quote Originally Posted by flynn_aus link=1226635869/0#1 date=1226637284
    8 bar is way too low. this is the system pressure which needs to up around the 10-10.5 range in order to achieve 9bars at the head. once that is adjusted, then youll need to see if its running too hot as well.
    as flynnaus mentioned, it wouldnt hurt to take in and have one of our sponsors look at her.
    sd
    May 2008
    4,127
    Quote Originally Posted by htb link=1226635869/0#2 date=1226638334
    Its 8 bar on the front gauge. I am aware that it will be different at the group but from what I understand its usually lower not higher..
    The grouphead pressure is lower than what the pressure gauge shows.
    Under-extraction, as the water will be pushed through the grounds at a higher pressure, therefore faster
    Jul 2007
    539
    Quote Originally Posted by flynn_aus link=1226635869/0#4 date=1226638852
    Actually, I have heard that higher pressure produces SLOWER pours, not faster. Apparently this has to do with the puck getting more compressed under the higher pressure, therefore compressing the grind particles closer together and slowing the flow.
    htb
    htb is offline
    Jul 2008
    163
    Thats what I thought.
    Okay, so by sounds of it the pressure is low as suspected, any ideas on how/where to adjust this?
    I take it the hole in the top is for the temperature.
    I would take it to a site sponsor but I have car problems at the moment.
    htb
    htb is offline
    Jul 2008
    163
    I opened up the case, found and adjusted the valve. Its a remarkably simple machine.
    I just did a test shot and it hit just over 9 bar so an improvement but still a bit lower then what I think is right based on the theory that the group is 1 - 1.5 bar lower then the boiler.
    The shot definitely tasted better and less bitter. I will adjust it further tomorrow if I can sleep tonight :D *
    Thanks for the help!
    17,123
    By the way "htb"...
    How fresh is your coffee and is it good quality and also, which grinder do you have? ::)
    htb
    htb is offline
    Jul 2008
    163
    Hi Mal, I bought the coffee from Di Bartoli last week and am using a rocky to grind it.
    The pressure is now at 10 bar and I am getting a much better coffee :D
    17,123
    Excellent..... [smiley=thumbsup.gif]
  1. Vibiemme Domobar Levetta (Piccolo) - pressure issue
    By sootysam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th September 2009, 07:29 AM
  2. Brew Temperature of Levetta?
    By PhilMac in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd August 2008, 10:40 AM
  3. Levetta Brew Group
    By Iconiq in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th August 2008, 05:48 PM
  4. Best Brew Pressure
    By vicroamer in forum Brewing Equipment (non-machine specific)
    Last Post: 20th December 2007, 09:06 PM
