Results 1 to 2 of 2
Thread: Silvia OPV (again!)
    KJM
    KJM is offline
    May 2007
    688
    Silvia OPV (again!)
    I have a "new" Silvia - one of those with an adjustable OPV. Since there was so much on the web about how big an improvement can be had by bringing the pressure back to the "standard" 9bar I thought Id give it a go.
    First, I measured the pressure. I added a pressure gauge to the group handle. Unscrewed the spout - this reveals a 3/8BSPP thread. A gauge from the Hydraulics place was had for $10 - conveniently calibrated in kg/cm^2 - close to a bar gauge! A 3/8BSPP to 1/4BSPP adaptor (gauges will be either 1/8 or 1/4BSP - parallel or taper) attached the gauge. Hey presto - near enough 11bar.
    Adjustment to 9bar was trivial - about a 1/4 turn of the adjuster. The result? Interesting. My daughters beloved Daterra espresso - simply fantastic! I went as far as screwing the adjuster back in and pulling an 11bar shot. You can taste the difference! I was stunned.
    Recommended!
    /Kevin
    Oct 2008
    505
    Re: Silvia OPV (again!)
    Great idea, thanks!
    I actually backed off my OPV about a week ago. Went by flow measurements.
    Put on the pressure gauge. I was spot on! Didnt need adjust.
  1. Miss Silvia (Rancilio Silvia)
    By zeke in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st January 2011, 07:59 AM
  2. is silvia 2009 $200 better than silvia 2008?
    By stevekat100 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th January 2010, 11:15 PM
