Results 1 to 4 of 4
Thread: Silvia steam control problem
    May 2007
    Perth, Western Australia
    3,163
    My steam control valve has stopped working and makes horrible sqeaky noises, how difficult is it to replace or repair? Has anyone done this or will I need to go to a technician? :( :( :( :( :(
    Mar 2008
    554
    Re: Silvia steam control problem
    It can be an easy job depending on how handy you are. I did mine without any difficulty at all. I helped another person (b E-Mail_m who totally muffed the job, broke off the brass adapter/reducer double-threaded thingy at the back side and bent the copper piping to the point that it had to be replaced.
    If you are good with hand tools and have a modicum of common sense (lets say that you feel comfortable replacing a fuel pump or rebuilding a carburetor and are god a Tetris) then it probably can be done.
    On the other hand, if the phrase "assembly required" has you phoning a friend then maybe not so much.
    There are four O rings (including the two on the steam wand, and the valve seal (like a washer as found in some faucets). Be sure to also get some food-safe silicone lube to lube things up when assembling. The valve seat is stainless steel, so probably all you need are the parts mentioned above.
    Apr 2007
    596
    This guide should get you started.
    http://www.coffeeco.com.au/articles/repair.html
    May 2007
    3,163
    Thanks for the feedback Randy and Vicroamer, I should be able to do the job........much appreciated!!
  1. Replies: 4
    Last Post: 2nd March 2013, 01:27 PM
  2. Replies: 4
    Last Post: 3rd May 2012, 09:17 PM
  3. Rancilio Silvia PID diy. How do I install steam control?
    By newbiemocca in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th November 2010, 12:12 AM
  4. Replies: 12
    Last Post: 14th April 2009, 08:19 AM
