Results 1 to 5 of 5
Thread: Surfing Silvias Wild Temperatures
    Feb 2005
    3,073
    Ive taken several readings using a new Digital MultiMeter (DMM) with a temperature function with K-type thermocouple (t/c) taped midway down Silvias boiler. *
    These temperatures fluctuate much more wildly than I thought. *From 86 to 109 degrees. *Thats 23 degrees. *Way beyond the 10 degrees mentioned to prevent thermostat burnout.
    And the element switches on and off inconsistently depending on whether the machine is cold or at operating temperature (about 40 mins pre-heat).
    These two lots of readings were taken at *operating temperature in different times of the day, starting at zero seconds when the light comes on (heating element switches on) *and at mostly 5 second intervals thereafter for 2 minutes. *
    light on 86 * 86
    10" * * * 86 * 86 * *
    15" * * * 87 * 86
    20 * * * *89 * 87
    25 * * * *90 * 89
    30 * * * *92 * 92
    35 * * * *94 * 94 *
    40 * * * *97 * 97
    43 * * * *98 (light off) *
    45 * * * * * * * 99 (light off)
    50 * * * 103 * 102
    55 * * * 105 * 105
    1 0" * *107 * 106
    1.10 * *107 * 108
    1.20 * *108 * 109
    1.30 * *109 * 108
    1.40 * *108 * 108
    1.55 * *107 * 107
    2.0 * * 106 * 107 *
    It will come as no surprise that heating continues after the light (and heater) switches off. What is surprising is by how much.
    From just under 100C *in the mid 40 seconds, to 109C.
    Residual heat and convection (water nearest element conducting heat to outer reaches of boiler) continues steadily for another 35 - 47 seconds.
    The maximum temperature reached is 109C. *But a fairly stable band is reached *between 1 and 2 after the intitial heat cycle begins...then starts dropping off again.
    So, what of all this data? * Well, in the absence of a PID, Ill now experiment *to manually cycle the heating element, using the steam switch, to prevent under or over-shooting.
    Im not talking about the usual temperature surfing: wait 40 seconds and away you go.
    At that point the temperature is still rising, though theres probably a counter-acting affect from incoming cold water. *Well see. *
    Should be fun.
    In any case, hope this data is useful and demystifies whats going on inside that brushed stainless steel box.
    Robusto
    14,665
    Re: Surfing Silvias Wild Temperatures
    stay tuned for results on the mega-bling, pimped sylvias once the luca and chris sylviasteins hit the test bench....at this stage the list of jobs includes:
    • superpid with dual set points
      pressure mod
      ball joint steam wand
      perhaps some neon on the undercarriage?? *;D *8-)
    And why are we gonna do it....because theyre there and were curious to see just what can be done with this machine...Am not touching the giotto tho *;)
    Mar 2005
    30
    Chris,
    Is that the steam wand from the sunbeam you were considering at roast-a-rama? so it fits? Wonder if it would fit my mokita.
    We should pitch a show to cable where Paul Basset rocks up to someones door, takes thier machine to a speacialised coffee chop shop and tricks it out. Itd be called Pimp-Yo-Coffee-Machine. Or maybe Pizzle-Yo-Coffee-Mashizzle Fo Shizzle, Ma Nizzle
    Luke
    14,665
    its off one of the machines at the academy, Luke....will report back if it fits.... :D
    Mar 2005
    30
    waiting with baited breath.
  1. Upper and lower heating temperatures
    By darmstrong in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 14th July 2009, 06:42 PM
  2. Gene roast times and temperatures for starter pack
    By fred in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st August 2008, 10:23 AM
  3. Corretto & Colder Temperatures
    By bolb in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 17th April 2008, 04:54 PM
  4. Espresso temperatures
    By pszilard in forum General Coffee Related...
    Last Post: 28th December 2006, 02:59 PM
