Results 1 to 5 of 5
Thread: Nuova Simonelli Mia Problem
    Nov 2005
    2
    Ive just purchased a second-hand Mia. The claim was that it was a gift and had never been used. From looking at it that seems likely.
    Now that I have fired it up I have a problem. Ive followed the directions in the user manual and the first time it worked, but now ... The Mia does not have a self-priming pump, so when I first filled it with water I primed it as per the instructions. Water came out of the steam wand and the group as the instructions indicated. I then ran water through the group as if I were making coffee. I then followed the directions for making steam and it seemed to steam quite well, except that when I turned the steam switch off it kept steaming for about 30-40 seconds. Eventually the steam fizzled out.
    Now, I can get water to run through the group to make coffee, but I cant get it to make any more steam. If I follow the directions for making steam I get a few drips of water out of the steam wand. If I keep pressing the steam buttons for about a minute steam starts to come out from near the group but nothing other than a few drips from the steam wand.
    Any ideas as to what has caused my problem? Any suggestions for fixing this?
    Thanks for your help.
    Richard
    Aug 2004
    2,312
    Re: Nuova Simonelli Mia Problem
    Gday Richard.
    Another great little machine, ahead of its time. May well date back to 1985 or earlier!
    Sorry to contradict but actually it is a self priming pump, and the priming action you must follow when you have either drained the reservoir or after you have made steam, is quite normal for all domestic boiler machines.
    ....I then followed the directions for making steam and it seemed to steam quite well, except that when I turned the steam switch off it kept steaming for about 30-40 seconds. Eventually the steam fizzled out.
    From memory, the steamer on the Mia is solenoid controlled and if it did not stop steaming alsmot immediately the button was released, this probably means there is some gunk around the slug inside the valve which is slowing the return spring from returning immediately. It may clear of its own accord or someone may have to dismantle & clear or replace.
    ....Now, I can get water to run through the group to make coffee, but I cant get it to make any more steam. If I follow the directions for making steam I get a few drips of water out of the steam wand. If I keep pressing the steam buttons for about a minute steam starts to come out from near the group but nothing other than a few drips from the steam wand.
    As long as the water pump is working, thats good. As long as the water coming from the group is properly hot, thats good (meaning the element is ok). The steaming coming from the group area indicates you are producing steam when deprtessing the steam button, but if it is not *being released out of the steam pipe, then it is simply overpressurising out of the pressure relief valve in the group area.thats good too....but seems like the electrovalve is not re opening.
    Sounds like the steam solenoid valve needs attention or replacement... OR, the controlling push button but if there is a probloem with the button, the thing is a four (from memory) *button but SINGLE switchblock so a complete new switchblock would need to be sourced.
    Needs service Im afraid.
    Regardz,
    FC.
    Nov 2005
    2
    Thanks for the information. I suspected something along these lines and a need of service. I was just hoping it might be a user serviceable cleaning that was needed.
    Does anyone know of a good dealer / service agent in the Brisbane area?
    Richard
    PS The comment about the self-priming pump was just a quote from the user manual.
    Aug 2004
    2,312
    Look up yellow pages, "coffee brewing equipment & supplies" for Brisbane.
    Jondhal (or some such spelling) used to be simonelli agents but there have been a number of changes to simonelli agencies and you may have to chase around and ring sydney / melbourne etc.
    Good luck,
    FC.
    Apr 2005
    1,176
    You might want to try Koffeetek in East Brisbane. They service any machine and have a great deal of experience and expertise. The owner, Wayne, actually restores machines, so age is usually not a problem.
    Good luck
  1. Nuova Simonelli Elli
    By CaffieneHit in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 2nd June 2011, 06:04 PM
  2. Nuova Simonelli MDX/MDM
    By Greg41 in forum Grinders
    Last Post: 3rd November 2010, 12:36 PM
  3. Nuova Simonelli Resto
    By seedlings in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 5th November 2008, 02:32 AM
  4. Nuova Simonelli Oscar
    By hotdog in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd June 2007, 04:58 PM
