Results 1 to 7 of 7
Thread: Gicar autofill units
    Jul 2004
    62
    Can anyone point me to wiring diagrams or other info on these boxes? Would be handy in diagnosing my problems with one group/controller. Im an elec engineer but my clairvoyance on the internals of unknown black boxes is dodgy.. :) A web search didnt turn up anything useful either. I can probably deduce much if I opened it up but hoping to do external diagnosis initially.
    Many thanks,
    Dennis
    Mar 2004
    200
    Re: Gicar autofill units
    Does it have a wiring legend/diagram on top? I guess not or you wouldnt be asking ;)
    I can post some photos of the legend on the top and bottom of my Gicar controller if that helps. Its a subject close to my heart at the moment as I have a mystery wire left over from a rebuild which terminates in the aforementioned blackbox :o .
    Ill take some shots later tonight if interested and post em up
    Apr 2005
    1,176
    Sean Lennon did a detailed analysis on the electrics of his Expobar Brewtus, that would include an autofill circuit. Its available from the Brewtus user group web site. Its a manual for adding PID controllers to the machine, but first goes into detail about how the stock machine actually works.
    Other than that I suggest you try the home-barista site. Sean and plenty of other tech types frequent that site.
    Good luck.
    Mark.
    Jul 2004
    62
    Thanks for the replies guys. Ill check out the web sites Sparky mentions first and if I get no joy I might impose on you for the photos mauricem, thanks for the offer.
    Dennis
    Aug 2004
    2,312
    If the controller is dead, dead, dead, *just check the transformer inside for heat / burn mark and warped cover.... Otherwise if its not dead dead dead but some functions operate while others dont, check the relays & you will probably find burned points inside.
    The problem with the above for traders is the parts might only be worth 2 bob but it costs you 500 dollars worth of time wasting to find out you cant get some of these specific 2 bob bits in this country...so then you just turn around, pay the ransom, *& replace the controller witha *new one..........
    However, there is still the question of whether the contoller works but the water turbine for that group doesnt, OR vice versa.........
    If this is a machine where there are 2 independent main contollers, one for each group, try swapping them around from one side to the other...it only takes a couple of minutes to do. You can also swap the sender unit & paddle wheels around on the turbines to isolate one that might not be working.
    If on the other hand the machine is the type that has a couple of simple touch pads operating off a single main controller, no can swap it!!!!
    Just thinking out aloud....
    Ring me on 02 / 6280 7511. I have something for you.
    Regardz,
    FC.
    Apr 2005
    234
    Dennis,
    Have you isolated the touch pad from the equation?
    Mar 2004
    200
    Quote Originally Posted by lennier link=1131342094/0#3 date=1131404232
    Dennis
    pics of my setup are here,
    http://www.widebaymultimedia.com/cimbali/d1web/indexd1.htm
    probably of no relevance to yours :(
  1. Repair/rebuild GiCar units and Controllers
    By A_M in forum Off Topic
    Last Post: 14th March 2019, 01:12 PM
  2. ECM Giotto Repalcing the Gicar control box help
    By Argy_Bargy in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th July 2015, 07:54 PM
  3. Autofill probe
    By Apple in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 12th November 2009, 11:39 AM
