Results 1 to 7 of 7
Thread: How to replace steam wand on Saeco VV
    Jan 2009
    31
    Gday all!
    I want to replace the anemic steam wand on my via venezia. If you take the plastic thing off it cant reach down in a bigger jug.
    Is it possible? (Surely). Anyone done anything similar?
    May 2007
    Perth, Western Australia
    3,155
    Re: How to replace steam wand on Saeco VV
    I suggest you get a 300ml jug, I found the Via Venezia didnt have enough grunt for anything larger.
    ev
    ev is offline
    Jan 2005
    156
    The 600ml jug was perfect for my old VV. The secret is to leave the Panarello on & remove the outside piece. This will give you a long enough wand with a single hole in the bottom. I used to get great microfoam with that set up.
    Evan.
    Jan 2009
    31
    Ok, sounds like I need steaming tips rather than gear mods!
    Jan 2009
    31
    Evan, do you have any tips on how you got that microfoam?
    ev
    ev is offline
    Jan 2005
    156
    Its been a few years but here goes:
    Drain water from steam wand
    Fill "Incasa" jug to just under the bottom of spout (enough for two lattes)
    Dip tip into milk & open steam knob (full)
    Quickly lift tip just under milk surface until you get the sweet "ts ts" sound
    Keep still until temp reaches 30 deg C
    Then dip tip deeper into milk & find the correct angle that allows the milk to create a whirlpool action. From memory you need to be at the edge of the jug with a slight tilt.
    Hope this helps.
    Evan.
    Jan 2009
    31
    Ok, so you create the foam first, then swirl that foam around in the whirlpool. I will give it a go, thanks!
  1. Saeco Via Venezia Panarello - replace with a Steam Wand!
    By CafeLotta in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 23rd June 2016, 08:39 AM
  2. replace steam wand on a em6910
    By evergreen in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th December 2011, 09:02 PM
  3. Replace Imat Mokita Steam Wand
    By Dimal in forum Brewing Equipment (non-machine specific)
    Last Post: 12th November 2004, 04:12 PM
