Results 1 to 3 of 3
Thread: Some explaining please
    Jul 2008
    145
    Hi All,
    I was just forward planing my next machine and have come across a term that I dont fully understand.
    The Term in question is HX (heat exchange).
    Is this the thermoblock type of construction?
    I understand the boiler construction that is easy.
    Could one of you help me? I am sure you can.
    Regards
    Crisp Image
    Jul 2008
    Port Fairy
    2,993
    Re: Some explaining please
    Hi,
    have a read of Randy Gs new page on HX http://home.surewest.net/frcn/Coffee/hx.html In simplistic terms the brew water is heated as it passes through the boiler water but it is a separate tube. A Thermoblock is basically an electrical element wrapped around the water path to heat the water.
    Jul 2007
    Werribee, Victoria, Australia
    737
    I might be able to help Crisp Image as a boilermaker a boiler is pretty simple water is placed inside a pressure vessel and heated generally used to produce steam to heat stuff.But if you add a set of tubes inside that pressure vessel and pump cold water through the tubes you can quickly heat the water to a desired tempreture.However with a thermoblock as beanflying said, the water passes in direct contact with the thermoblock.I am no expert in thermoblocks.
