Results 1 to 11 of 11
Thread: Brewtus MKII
    Jul 2005
    74
    Brewtus MKII
    Hi ,
    I havent seen anyone taling about it on this forum but it seems that we have a Brewtus MKII . Take a look
    http://www.wholelattelove.com/Expobar/brewtus.cfm
    Certainly looks good.
    Jul 2004
    2,134
    Re: Brewtus MKII
    A few people have been talking about it. I think 2 even bought it!
    I think here in AU they call it the Expobar Minore EB-61
    Jul 2005
    74
    Re: Brewtus MKII
    Hi Fatboy,
    Are you sure that its the same one , even on expobar australias website they only have the one model listed . All the major online Aussie retailers Ive looked at only have one model as well . One thing I notice on all the models available in Australia is that they only have the one pressure gauge(for steam pressure) that was available on the initial model , they dont seem to have the brew pressure gauge as well.
    But who knows maybe they havent updated their website.
    May 2005
    Perth
    1,351
    Re: Brewtus MKII
    It is probably inevitable that the updated model will make its way to Australia but I would guess it will take several months or longer just like the original model.
    Grant
    Feb 2005
    441
    Re: Brewtus MKII
    Yeah, its not out here yet. I get the impression that it will be out later next year.
    Apart from the 2 pressure guages, its also got an insulated steam arm, and probably a few other fancy gadgets.
    May 2005
    1,993
    Re: Brewtus MKII
    Quote Originally Posted by mattyj link=1134647656/0#4 date=1134688771
    Yeah, I think that we wont get it until at least Feb.
    Ive heard tell that it not only has the insulated steam arm, but also spring valves, like a commercial machine. Many domestic machines use compression valves, which can be screwed up after a while and start leaking, needing to be rebuilt. With the compression valves, you cant screw them in very tight ... and if, for some reason, you do have to rebuild one, the parts are cheaper. Chris Nachtrieb added photos to his explanation here: http://www.chriscoffee.com/faq#18
    WLL also says that its possible to adjust the brew pressure using a knob that can be accessed simply by removing the drip tray. No more taking the whole shell off and fiddling with barrel adjustments! Id imagine that you could go from 88C, 8 bar to 95C, 9.5 bar very easily indeed ...
    Luca
    Rae
    Rae is offline
    Aug 2005
    3
    Re: Brewtus MKII
    Just reviving this old thread rather than starting another one....
    I really like the look of the Expobar Brewtus II, and wonder if anyone has heard anything on availability in Aus (I guess that would make it the Barista Minore II) anytime soon?
    Cheers and TIA...
    Jan 2006
    22
    Re: Brewtus MKII
    Quote Originally Posted by Rae link=1134647656/0#6 date=1139320202
    Cheers and TIA...
    I was told April by an Expobar dealer, but there were no firmer commitments
    Rae
    Rae is offline
    Aug 2005
    3
    Re: Brewtus MKII
    Appreciate the info.... many thanks. *:)
    I have read conflicting info on whether the US version Mk II is vibe or rotary pump - does anyone know which is correct?
    Feb 2005
    441
    Re: Brewtus MKII
    its optional here in oz. you can get either pump. I think to rotary costs more though.
    Rae
    Rae is offline
    Aug 2005
    3
    Re: Brewtus MKII
    Thats great - many thanks for the info, mattyj.
    Cheers.
  1. Bucket Cooler MkII - advice required
    By Thundergod in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st January 2009, 08:52 AM
  2. Expobar Minore/Brewtus II
    By TC in forum Brewing Equipment (non-machine specific)
    Last Post: 3rd April 2006, 08:59 PM
  3. Brewtus
    By Mark in forum Brewing Equipment (non-machine specific)
    Last Post: 17th September 2005, 07:13 AM
  4. Expobar Brewtus
    By Framey in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd January 2005, 12:43 AM
