Results 1 to 5 of 5
Thread: Aligning the spout
    Nyg
    Nyg is offline
    Oct 2005
    13
    Aligning the spout
    On my coffee machine the spout on the portafilter is no longer correctly aligned. In fact it is 90 degrees out of place meaning I have trouble getting two cups onto the tray.
    Does anyone have a suggestion as to how to fix this. If I loosen the spout to it is parallel with the front of the machine, it is all wobble.
    Dec 2005
    370
    Re: Aligning the spout
    Teflon Plumbers thread seal Tape. or a small shim or both
    Tepin
    17,463
    Hi Nyg,
    Another method you can try and one that I have been using for the last 2years or so, is to take a trip down to your local hardware shop or Repco, etc with your PF in hand and ask them to find an O-Ring that fits snugly over the thread on the PF. Buy a few of these (I got 10 for $1.50) and Bobs your uncle.
    When you get home, just put one of the O-Rings on the PF before you spin the Spout back on and when its getting close to proper alignment, lock the PF into place (with basket) and adjust for final position. Its all too easy and so far, Ive only gone through 2 O-Rings in 2 years.... works out to be 15 cents per year, not bad ;).
    Nov 2004
    Augustine Heights QLD
    302
    Gday Nyg,
    There may be another option. I had the same problem with my Silvia PF. The factory had used a tread stopper (a bit of string), which I removed during the first clean. Hence the spout screwed up to 90 degrees out (it was inline with the PF handle). Since the threaded orifice of Silvias spout is deeper than the threaded nipple on the PF handle, I removed some metal off the spout with a linishing belt and some wet and dry abrasive paper. Rub it a bit then trial fit until it screws on perfectly aligned. Yes it does take off the chrome plating, but you cant see itís missing because itís hard up against the PF housing. And it doesnt come into contact with the coffee.
    No more buggerising around with o-rings, tape or gaskets. ;)
    Boris
    Nyg
    Nyg is offline
    Oct 2005
    13
    Thanks guys, I will give your suggestions a go..
  1. portafilter spout
    By walshman in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th March 2011, 07:11 AM
  2. Replies: 6
    Last Post: 2nd February 2010, 06:56 PM
  3. Hot water spout on HX
    By Cervelo in forum General Coffee Related...
    Last Post: 16th December 2008, 02:36 PM
