Results 1 to 34 of 34
Thread: Miss Silvia questions
    Sep 2004
    30
    Brousing this web site is expensive, it just cost me $639, but for that i got a shiny new Rancilio Silvia (Mocopan). So my first question is (the manual is pretty useless), do I need to empty the boiler everytime I switch her off, and if so, how? Next, I was thinking of complimenting my Miss Silvia with a Iberital Challenge grinder. Any opionions on this choice? The Rocky just seems too expensive. Gotta go, my wife is demanding more Caffeine. More questions to follow.
    admin
    Re: Miss Silvia questions
    Glad to see we have you tempted to spend your money! ;) Keep the boiler full, ESPECIALLY if you are keeping her on a timer. Get into the habit of refilling the boiler every single time if you are steaming. Its not really an issue if you are just pulling shots.
    As for the grinder, we upgraded from a little Russell Hobbs bur grinder to a Solis 166 when we got our silvia and we were sorry that we didnt just put that money toward a rocky sooner, we wouldve saved ourselves $195, both grinders went to good homes though.
    Rich
    Sep 2004
    30
    Thanks for the tips. The manual often prompts you to refill the boiler, but its not clear on how to do this. What do you recommend? Sorry for the basic questions, I really am a beginner!
    ed_vinas
    Quote Originally Posted by cafeoholic link=1096021673/0#2 date=1096027346
    Cafeoholic,
    What I do is run hot water into a jug for a few seconds (maybe 5-10) at the end of every session. This way I know the boiler is full and leaving it on for any period of time won’t be a problem.
    Welcome to the fold.
    Ed
    Jul 2004
    2,131
    There are a number of articles around - here is a link to one
    http://members.dodo.net.au/gregnmim/FAQ.htm
    Apr 2004
    327
    Without BLOWING my own trumpet... I like my Tamper more,,,,I had a laugh
    http://www.coffeesnobs.com.au/cgi-bi...num=1091580521
    Cofeoholic... you wanted a good excuse to give to the wife..(Ministress of Finance) tell her that it basically guarantees a 50% better result in coffee. why...because it does. Tell her FrenchBean says so, and hes a good bloke...hehehehe
    as Ed said welcome to the fold, indeed you are welcome.
    May 2004
    439
    Quote Originally Posted by cafeoholic link=1096021673/0#0 date=1096021673
    The Iberital is a fine grinder - better than the Rocky in some ways (infinite grind settings, less grinds left in doser for those versions, usually more stable burr carrier). The Rocky is more solidly built but for domestic use, that shouldnt matter. The Rocky can be easily tweaked to overcome these issues (toothpick wedging for adjustment, sweeper extensions to doser vanes, teflon tape on upper burr carrier) but it does cost more.
    May 2004
    439
    Quote Originally Posted by CoffeeSnobs link=1096021673/0#4 date=1096028243
    Either run water through the group or run water through the steam wand which also has the effect of cleaning it and filling the boiler.
    You really need to run water through the steam wand of a dual purpose boiler machine to ensure that it is filled properly. This is because the boiler gets filled from the bottom while steam is taken from the top and group water is taken from the middle area (through a tube) so an air pocket will not be cleared through the group.
    admin
    Running water through the group has the same effect of filling the boiler plus rinsing the shower screen.
    Rich
    Sep 2004
    30
    Thanks for all the help. The story so far.......the coffee is much better than the first attempts, but I am still struggling to get 2 good strong cups from a double shot, using the double basket. I havent invested in the grinder yet (very soon), but have tried a few different "shop" grinds. I have also concentrated on getting the tamp right. My first improvement (on the plastic job) was to use a flat bottomed drinking glass. A vast improvement. I have taken a leaf out of FrenchBeans book, and gotten myself a huge lump of brass. Its now 58mm diameter, 110mm long and weighs in at 2.1Kg, and I can see my reflection in one end (uugh!!!). I havent had time to test it yet, but will report back soon. Next question....am I expecting too much in terms of coffee strength, should I persever in prefecting my technique, or splash out on a Morzocco 14g or 18g basket?
    May 2004
    439
    Quote Originally Posted by CoffeeSnobs link=1096021673/0#14 date=1096536374
    It doesnt. Gas that is above the level of the tube feeding the group head will not be cleared this way. Only by priming through the steam wand will the boiler be completely filled.
    Quote Originally Posted by cafeoholic link=1096021673/15#15 date=1096632924
    You wont get consitent improvements without a decent grinder - it is as important as the machine.
    admin
    I pulled the top off my Silvia for a look. Except for about 3mm either method of filling the boiler will do the trick. ;)
    So long as you run water through something you cant go to far wrong. :)
    The important thing is not to leave the boiler empty.
    Rich
    May 2004
    439
    Quote Originally Posted by CoffeeMugs link=1096021673/15#17 date=1097498210
    So the feed to the group head comes from that far up the boiler? I thought the cold water inlet would start feeding directly to the group if it was that close. Oh well, as long as the heating elements arent exposed, then things will be fine.
    Sep 2004
    30
    Maybe the take off for the group head is on the top, but internally, the pipe extends to the bottom of the boiler. Just a thought. Tried looking on the "coffee parts" website, but the boiler isnt on the parts sheets.
    3
    Hi all, Im a bit confused - do you ensure the boiler is full by running water out of the group/wand by using the "BREW" or "HOT WATER" button? (Silvia)
    Mar 2004
    70
    Yaukwang,
    Quote Originally Posted by yaukwang link=1096021673/0#14 date=1098341060
    If you have a Sivia the instructions are in the manual. In my copy of the manual (p32) under "fill the water tank" with a few word changes:
    • Release filter handle, open the steam tap, press the main switch and at the same time presss the coffee switch.
    • When water begins to come out of the steam pipe, close the steam tap and allow water to flow from the coffee outlet for a few seconds after which time the coffee switch 3 should be switched off.
    In summary, Rancilio recommends using the steam/hot water outlet AND a finishing flush through the Group.
    cheers,
    Graeme
    3
    I am thinking of getting my OH an espresso machine for Christmas and am feeling rather swayed towards the Sylvia . I have seen mentioned that you can get it cheaper at mocopan . Where are they located ? I am in Melbourne .
    Sadie
    ed_vinas
    Quote Originally Posted by Sadie link=1096021673/15#16 date=1098372690
    Sadie
    Sadie,
    Mocopan are in Preston - http://tinyurl.com/5r7kn
    Ed
    admin
    Sadie you wont go wrong with a Silvia.
    Make sure you tell Mocopan that we helped you decide.
    I think 5 or 6 ppl have brought thier Silvia from Mocopan as a result of descussions here.
    Rich
    Jul 2004
    2,131
    Sounds about right ;D
    I really love our Silvia. Especially this week. Kenya AA Masai has been a particularly yummy roast this week. 8)
    Apr 2004
    327
    Country NSW has a new distributor for Racilio gear as well............. There prices are good as well, We bought a KitchenAid K5 mixer from them for nearly $500 less than RRP, nice people to deal with too.
    If I didnt have my Boema I would be looking at the Sylvia too!
    FB :-)
    Aug 2004
    15
    FB
    You said "Country NSW has a new distributor for Racilio gear as well"
    Who is it and where are they based?
  23. #23
    Apr 2004
    327
    Sorry Chris, I cant tell you on this forum as it is not allowed, against the rules.
    FB :(
  24. #24
    admin
    Yes you can FB us recommending places is allowed but them comming here of thier own accord and thinking they can advertise for free isnt.
    So spill the beans ;)
    Rich
  25. #25
    Apr 2004
    327
    Bundella Distributors Molong. NSW Ph 02 63668778... Pracilla/Prassilla is the lady you need to speak to.
    Thank Rich, Chance of them adverting or commoing on the net would be limited....... Ill explain to you why later
    FB :)
  26. #26
    Nov 2004
    53
    Does anyone know where I can buy a Rancilio Rocky and Silvia combo? Sienna and coffeeco both seem unable to supply at the moment. Ive spent months saving up to buy a Silvia but now I have the money they arent available (seemingly).
  27. #27
    admin
    Try Mocopan in Melbourne
    Rich
  28. #28
    Nov 2004
    2
    Another New Miss Silvia owner and question
    Hi ppl,
    We became the proud parents of a mIss Silvia on Tuesday and have started on the learning curve to a perfect coffee.
    We purchased the Rocky as well as the local reseller did a good deal. My first question of many to come.
    When I empty the portafilter after making a cup the spent grinds are a lot wetter than when the dealer was showing me how to do it. What would be the cause of this?
    Leigh
  29. #29
    Jul 2004
    2,131
    There are a few options.
    Could be not enough coffee in the portafilter.
    Could be the tamp is not correct.
    How is the coffee and the crema coming out?
    If it is not very strong, then the grind might be too coarse.
  30. #30
    Apr 2004
    327
    Part of your problem could also be that your grind is too fine.
    Also remember that with different roasts also comes different grinding grades.
    Nice to hear you becoame the proud Parents, Does she sleep all of the way through the night.... ;D
    You will also find that the Coffee Grinds left over after you brew are also very good for your garden.
    Welome to CS Mundi
    FB :)
  31. #31
    Nov 2004
    2
    Thanks guys,
    The crema is ok but not great, and the coffee is a good strength. Is it possible to over tamper or in other words over compress the grind?
  32. #32
    Nov 2004
    53
    Hi Mundi
    If you tamp too hard youll end up with no shot as the pump wont be able to push water through the grounds.
    Mick
  33. #33
    Sep 2004
    30
    Hi Mundi,
    Ive found when I first got my Silvia (only a month ago), I was getting good looking, dry pucks out of it. But I soon discovered I was using too course a grind (shop ground). I think I have now got this right, the coffee tastes much better, great crema, and stronger, but the pucks now come out wet on top if I remove them immediately after brewing. But if I leave them in for just a minute or so, they come out pretty dry - so Im not sure when you should gauge the "dryness". I bet this hasnt helped you one bit, I just wanted to assure you that youre not the only one on that steep learning curve.
  34. #34
    Feb 2005
    2,974
    An Iberital grinder goes very well with Miss Silvia. I chose one without the doser, so it grinds directly into the portafilter basket. The adjustment is very fine and continuous, no knotches or detents which can over- or under-compensate the grind. Furthermore, it has a neat little timer (a screw) and pressing the portafilter against a switch under the holder turns it on.
    Needless to say, the shots are fantastic, with a deep, dark crema. I recommend using glass instead of a cup so the crema formation can be appreciated more.
  1. !!!SOLD!!! - Miss Silvia Gen 1.
    By jtaus67 in forum SOLD
    Last Post: 18th October 2013, 12:18 PM
  2. Miss Silvia Gal
    By spencarr in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th February 2010, 10:34 AM
  3. RIP Miss Silvia
    By XenneX1969 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th July 2009, 05:57 PM
  4. Welcome Miss Silvia!
    By porschemad911 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th June 2008, 07:58 PM
  5. Miss Silvia...here I come!
    By FourO in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th February 2007, 10:31 AM
