Results 1 to 7 of 7
Thread: E61 Group Head for non-HX machines
    Jun 2009
    37
    Can someone explain the mechanics of the e61 group head on a non-HX machine?
    I understand how it works for HX machines but am curious as to how it works - as in where the water which cycles around the head is drawn from - for a dual purpose single boiler. I cant understand how the cycling water does not end up back in the boiler?
    This is purely an exercise in curiosity.
    Dec 2007
    921
    Re: E61 Group Head for non-HX machines
    Just did a quick search and one way of doing it is to bolt the grouphead directly to the boiler. I would assume that you could have it independently heated by its own element (think I have heard of that). That would seem to be the two main ways it could be done.
    14,665
    The groups are attached traditionally.
    The difference is that in a HX machine, the boiler is at well over 110 deg.
    In dual purpose single boiler machines (at least the good ones), rheostatic control allows for the boiler to be accurately set to brew temperature withthe use of a Scace device. This is why theyre so much better than a Silvia for example...
    When you press the steam button, the steam thermostat takes over and raises the boiler temp for milk texture...
    Hope that helps...
    2mcm
    Sep 2009
    1
    the steam thermostat takes over and raises the boiler temperature for milk texture so that is the process...
    Jun 2009
    37
    Quote Originally Posted by 18475F494249454C4C4F4F474B442A0 link=1252111473/2#2 date=1252141689
    ... allows for the boiler to be accurately set to brew temperature ...
    Thanks for that.
    Does this mean that a single boiler e61 machine does not require the use of a cooling flush if the machine has been sitting idle for an extended period because the water should always be sitting at brew temp?
    14,665
    Quote Originally Posted by 202728253F3627283235460 link=1252111473/4#4 date=1252204175
    Correct- assuming it has been Scaced to set it correctly. A whole heap of vendors dont bother doing this....
    Jul 2007
    2,288
    Quote Originally Posted by 212629243E3726293334470 link=1252111473/4#4 date=1252204175
    Id say "both yes and no". The water in the boiler might be the right temperature for brewing, but the group etc. will likely be cooler and so the machine may need a heating flush for the first coffee after idling, but succeeding cups are OK.
    If the boiler is set so the first coffee is right without a flush, then the succeeding coffees in a run may well be too hot.
    Keeping everything at the correct temperature for both idling and running would be very difficult, especially when the difference between too hot and too cold could be as little as 2C.
  1. Group head seal help
    By blaggon in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th February 2012, 11:08 PM
  2. Group head Q?
    By liamo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 25th December 2009, 06:00 PM
  3. Triple Group Head Machines
    By Harlen_Coffee_Kid in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 12th December 2009, 09:44 PM
  4. E-61 vs E-64 group head
    By Vicomte in forum Brewing Equipment (non-machine specific)
    Last Post: 1st April 2009, 09:22 PM
  5. E61 group head Schematics
    By Clinto in forum Brewing Equipment (non-machine specific)
    Last Post: 5th September 2006, 06:41 PM
