Results 1 to 7 of 7
Thread: the tamper... thoughts on purchase
    Oct 2009
    Townsville, Queensland, Australia
    43
    So i considering a range of options for a tamper... (for my EM6910)
    1) a 60-100 dollar tamper 58mm and buying a scale with it to measure weight
    2) the 15kg tamper(the one that clicks when you obtain 15kg) from coffeehits (for consistant tamping weight) for $130
    well ok... only 2 options... the 3rd is more so based off what you guys suggest or consider to be a good idea... I am quite adamant to get the 15kg right which is why i thought the 15kg click tamper would be a good buy...
    your ever trustful and thoughtful opinions shall be treasured :p
    Apr 2008
    Brisbane
    5,115
    Re: the tamper... thoughts on purchase
    The Espro click tamper is a tamper that many CSers use & love
    I personally like & use the Pullman Barista its in the same price as the click tamper
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4E497F7A7B1E0 link=1258882305/0#0 date=1258882305
    It is a rule of thumb and many with lots of experience will tell you that 15Kg is not every thing..
    It is a balance between a number of factors...
    The variables are the;
    BEANS
    Grind size
    Dosing Level
    TAMP method
    TAMP pressure
    Every one is variable and each one causes a ripple effect...
    Then there is the issue of flat / convex or concave shower screens....
    At the end of the day... Its whats in the cup..
    10,496
    I wouldnt spend money on a tamper for a 6910.
    The Sunbeam tamper should suffice until you upgrade the machine.
    Its a pretty good fit and an off the shelf tamper wont fit any better.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 0C302D363C3D2A3F373C580 link=1258882305/3#3 date=1258892240
    Tend to agree as I also never use a heavy tamp.
    Get some fine wet and dry and polish the base of teh SB tamp... It will mak a world of difference.. Well it did fo me as the ones I got had quite obvious machining / grinding marks and when twisting with a FINE grind... It would not polish the coffee...
    Oct 2009
    43
    Quote Originally Posted by 6D424B495E614D424D4B49414942582C0 link=1258882305/4#4 date=1258926823
    Get some fine wet and dry and polish the base of teh SB tamp... *It will mak a world of difference.. *Well it did fo me as the ones I got had quite obvious machining / grinding marks and when twisting with a FINE grind... It would not polish the coffee...
    polishing in a circular motion is recommended in this case?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4641777273160 link=1258882305/5#5 date=1258966137
    YES... Sorry..... A nice number 8 pattern.
    Emery paper on a flat surface and then using small movements in a number 8 pattern... You will soon see the difference...
  1. Thoughts please
    By Migoo in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 23rd September 2014, 07:58 PM
  2. Espro Tamper or Pullman Tamper - Looking for CSers opinions
    By at535 in forum General Coffee Related...
    Last Post: 20th February 2009, 06:13 PM
  3. any thoughts?
    By Derkdigler in forum Brewing Equipment (non-machine specific)
    Last Post: 25th January 2009, 09:46 PM
