Results 1 to 6 of 6
Thread: Tampering ;) with the Espro
    Jun 2007
    85
    Happy New Year, folks !!!
    I have an Espro tamper, which I am quite happy with, but would like to modify...I like the handle and the 30lb click mechanism, but want to add a Pullman base fitted to the Syesso baskets.
    I have emailed Greg about this, and he suggested that I first try to remove the base from the handle....I found references on a couple of websites that indicate the unit cannot be disassembled.
    Has anyone actually tried to pull one of these apart, perhaps for repair?? ....I am loathe to try this for fear of ruining mine.
    The only option if this cant be done would be for Greg to tap a thread into the original base ... I fear the result may end up way too heavy ???
    thansk for any input,
    cheers
    Feb 2006
    2,334
    Re: Tampering ;) with the Espro
    Underneath the Espro badge may be a hex bolt holding the unit together. Im not sure....only one way to find out ;)
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    847
    Quote Originally Posted by 6143455E595345360 link=1262319294/1#1 date=1262944868
    Underneath the Espro badge may be a hex bolt holding the unit together. Im not sure....only one way to find out Wink
    There is indeed a hex nut under the badge, but undoing it wont get the handle away from the base. Ive tried to do this before on an old broken one. There is something else within the tampers innards that holds the handle and base together, I just havent found it yet.
    Mar 2005
    2,165
    It could well be something like a spring-loaded pin in the lower part of the tamper thats compressed, then slid inside the handle assembly where it could expand into a holding cavity. Thered be no way to get it apart without breaking it. I recall they advertised it as a one piece unit, and obviously it cant be literally one piece of metal that has moving parts but I guess in the sense that it cant be disassembled.
    Jun 2007
    85
    yep...as much as it pains me, it seems there is no non-destructive way to dismantle the thing...Greg, I will email you to discuss costs of threading the base to install one of yours, matched to the Synesso baskets...I think I will go with the convex base too.
    Thanks for your input, guys..
    buff
    14,665
    Quote Originally Posted by 3D2A39395F0 link=1262319294/4#4 date=1263851721
    buff
    Why not just get a Demaral? adjustable for pressure and depth- if that tickles your fancy ;)
  1. Tamper tampering
    By slippyfist in forum General Coffee Related...
    Last Post: 9th June 2010, 11:30 AM
  2. Is there a machine that does not require tampering
    By cupajoe in forum Brewing Equipment (non-machine specific)
    Last Post: 30th January 2010, 07:18 AM
  3. Espro tampers
    By kbc in forum Brewing Equipment (non-machine specific)
    Last Post: 29th July 2009, 11:55 AM
  4. Espro
    By Lovey in forum Brewing Equipment (non-machine specific)
    Last Post: 9th February 2009, 03:04 PM
