Results 1 to 10 of 10
Thread: Grindenstein: sticky knock ring
    Nov 2005
    50
    I have no idea what the "correct" terminology is (I would suppose that it has a name in the manufacturing industry, but I have worked as a barista and never known a specific name!) but I am refering to the actual rubber centre ring that makes contact with the group handle (thank you Andy for breaking bad habits!).
    I have just (as in 2 hours ago) purchased my long lusted after Giotto Premium Plus and Mazzer Mini combo from Chris at Talk Coffee.
    After setting everything up and letting the Giotto warm up, I pulled my Grindenstein down off the shelf to find that the rubber part has become disturbingly sticky!
    First off, what might have caused this? It has been in storage for at least a year (in pantry/cupboard that is) where it has been out of sunlight but not exposed to moisture.
    Secondly and *far* more importantly, does this present any risk to my new shiny baby? Could the "melted"/sticky rubber transfer to the group handle and damage the machine internals?
    Matt (who needs to use less parentheses)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Grindenstein: sticky knock ring
    Quote Originally Posted by 09000808130E0F041B140C08610 link=1262754539/0#0 date=1262754539
    Group seal = http://www.coffeeparts.com/misc/group-seals.html
    Once they have been exposed to water / coffee oils / Cleaning solution and then left for any time they perish and go sticky... Rubber and Si seals alike... Same for O-rings... Just a part of life.
    Jul 2007
    2,288
    As far as I know the Grindensteins are knock-boxes and wouldnt have such a thing as a group-seal, but a rubber bumper on the cross-bar.
    Other than that--yup, rubber perishes. Id replace it or take it off just in case any rubber stuck to the basket.
    Nov 2005
    50
    Quote Originally Posted by 230C0507102F030C0305070F070C16620 link=1262754539/1#1 date=1262759626
    Once they have been exposed to water / coffee oils / Cleaning solution and then left for any time they perish and go sticky... Rubber and Si seals alike... Same for O-rings... Just *a part of life.
    Quote Originally Posted by 25100705350D100F030E06620 link=1262754539/2#2 date=1262760886
    Sorry AM, Greg got it. I think I may have to bite the bullet and get a new knock box >.<
    May 2008
    4,117
    Quote Originally Posted by 202921213A27262D323D2521480 link=1262754539/0#0 date=1262754539
    Quote Originally Posted by 09262F2D3A052926292F2D252D263C480 link=1262754539/1#1 date=1262759626
    Group seal *
    Err...I havent seen any group seals on a Grindenstein knockbox AM *:P
    Matt - if you tap the grouphandle on to the knockbox bar (convenient non-technical term *::)), do you notice any rubber come off onto to filter basket. If so, just wipe it off before preparing your next shot. .
    You could also try clean the bar with ordinary detergent and water. Otherwise buy yourself a new knockbox. I had a Grindenstein and, with teh increased usage due to a wonderful GPP, I forked out for a newer and bigger one.
    Edit: Yep, well snap to Greg Ws response
    What part of Sydney are you in Matt? You can have my old Grindenstein if you want - well its less than 12 months old. I live in Ryde.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 3A302532323D292F5C0 link=1262754539/4#4 date=1262761268
    Bad day and Fat fingers and grubs between the ears..... That what ya get with 200kg of mangos rotting in the back yard *::)
    note to self... Drink more water.
    OK.. Same result... *Once *they have been exposed to water / coffee oils / Cleaning solution and then left for any time they perish and go sticky... Rubber and Si seals alike... Same for O-rings... Just *a part of life.
    Wash and or replace... * I use large Dia Si tubing and split it OR non ribbed garden hose...
    Back to the school room for me *;D :D ;)
    [edit]IMPORTANT UPDATE: Replacement Rubber Tube To fit: JB-230[/edit]
    http://www.coffeeparts.com/accessories/knocking-grounds-tubes-home.html
    So $4 and ya can have ya knock box back to standard... Phftttttt to every one else *:D ;) ;D
    May 2008
    4,117
    Quote Originally Posted by 5C737A786F507C737C7A78707873691D0 link=1262754539/5#5 date=1262761624
    Sorry AM thats strike 2. The part you listed is for the Compact Designs knockbox. I have one of these now and it has a completely different knockbar to the Grindenstein. I think your first idea was on the money - a piece of garden hose or similar that is slit and fitted over the existing bar.
    So the count is strike 2 ball 1 ;D
    Nov 2005
    50
    Quote Originally Posted by 6F65706767687C7A090 link=1262754539/4#4 date=1262761268
    Wow, I need to update that! I moved to Melbourne from Sydney in October 08!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 404A5F4848475355260 link=1262754539/6#6 date=1262762847
    So the count is strike 2 ball 1 *;D
    Can I blame my new reading glasses :o
    Jul 2007
    2,288
    Quote Originally Posted by 56797072655A76797670727A727963170 link=1262754539/8#8 date=1262766100
    Absolutely. Any excuse will do. :D
  1. Build your own knock box (knock tube)
    By Groggles in forum Brewing Equipment (non-machine specific)
    Last Post: 9th December 2014, 11:26 AM
  2. Replies: 5
    Last Post: 5th May 2013, 08:40 PM
  3. Dreamfarm Grindenstein knock box on sale $21.95 delivered
    By stonedewok in forum General Coffee Related...
    Last Post: 1st July 2012, 09:06 PM
  4. !!SOLD!!: Grindenstein Knock Box
    By chalermchait in forum SOLD
    Last Post: 29th July 2010, 03:16 PM
  5. Grindenstein Knock Box
    By coughienewbie in forum Brewing Equipment (non-machine specific)
    Last Post: 10th October 2009, 07:35 PM
