Results 1 to 6 of 6
Thread: Water leaking around sides of PF
    Jul 2008
    1
    Can anyone offer any suggestions as to why water is leaking around the edges of the PF. I cant tighten the PF any further. Could the rubber ring/seal be worn? It doest seem to be but then Im not sure
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Water leaking around sides of PF
    Quote Originally Posted by 4E5E524949624D3D0 link=1277468112/0#0 date=1277468111
    Errr toss a penny and check to see how long the string is... Then divide by two and you will have ya answer...
    Sorry... I can think of 101 reasons, but they may all be wrong as you have not provided teh extra information.
    How about some background...
    Age of machine
    What sort of machine
    What model
    What type of basket are you using
    What beans
    What grind
    How far are you locking teh group in
    What dose level
    How hard are you tamping
    Etc
    etc
    etc
    10,496
    Quote Originally Posted by 30202C37371C33430 link=1277468112/0#0 date=1277468111
    Welcome to Coffee Snobs.
    Questions:
    Where are you? (please update your profile)
    What machine?
    How old?
    When was the seal last changed?
    How often is the machine cleaned and how?
    Answers to some of those might help us guesstimate the length of the string.
    May 2008
    600
    if youve had it a while, why not change it to be sure. you could also check that the filter basket is not damaged. Good luck!
    Aug 2004
    2,312
    Welcome to CS Scott.
    a) group seal (or "undercup washer") worn;
    b) overpacking the coffee filter
    c) machine / model dependent: built up pressure may have at some time forced the group seal out of position, and grinds have made their way "underneath" it into the groove that it sits in, making the seal sit unevenly;
    d) use of incorrect coffee filter (americanspeak = "basket" :D)
    Tightening the group handle onto the group does not necessarily fix this kind of leak....just like when you overtighten a leaking water tap to try and stop it leaking, but it doesnt stop.....
    Over to you.
    Regardz,
    Attilio]
    very first CS site sponsor
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 25353922220926560 link=1277468112/0#0 date=1277468111
    It could be as simple as you are packing in to much coffee into the PF basket
    It is important that you find the correct dose or puck depth level after tamping for your machine
    That level is a hairs whisker from the water dispersion mesh on the group head
    And yes a little bit more info would help as we are not mind readers *;D
    Quote Originally Posted by 023E2338323324313932560 link=1277468112/2#2 date=1277474333
    Questions:
    What machine?
    How old?
    Whenwas the seal last changed?
    Answers to some of those might help us guesstimate the length of the string. *
  1. Water Leaking from Ikon
    By Secksy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th August 2011, 10:02 AM
  2. EM6910 leaking water
    By turando in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th February 2011, 08:29 PM
  3. Rancilio S26 - Leaking Water
    By Sacred_Cow in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 5th October 2009, 09:42 AM
  4. Sunbeam 6910 Water Leaking
    By weathdan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th June 2008, 10:13 PM
