Results 1 to 7 of 7
Thread: Silvia (again!) group head screen SCREW arghhh
    Apr 2006
    2
    Great to find an Auz based coffee forum!
    I have the legendary Silvia (for far to long for what I am about to admit!) and have never cleaned out the group head gasket or behind the screen - trouble is how the heck do you undo the screw - besides the obvious of course - it seems to be VERY VERY tight - or am i more of a weakling than I thought!!! ANY tips would be much appreciated as I am starting to strip the screw. Thanks in advance.
    Feb 2005
    3,058
    Re: Silvia (again!) group head screen SCREW arghhh
    The shower screen bolt does tend to over-torque itself. If your model Silvia has a hexagonal head bolt, then its best to remove it with a socket wrench.
    If its a slotted round-head, get a stubby screwdriver with a blade which isnt too loose a fit, press it firmly into the bolt to prevent the blade slipping off and damaging the adjoining screen as you try to loosen it.
    Persevere, but be careful.
    When you have removed it and scrubbed the screen -- therell be a lot of black gunk in there---replace the bolt finger tight only. Thats all it needs.
    Good luck,
    Robusto
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    848
    Gday Highalt,
    If your Silvia doesnt have a hex nut, you might find it easier when following Robustos advice if you turn the machine over. You can put more pressure on the screwdriver, and youll have a lot more control over it, plus its easier to see what your doing.
    If you do happen to strip the screw head, youll have to use a pair of locking pliers.
    If you dont know what they look like, have a look at this link:
    http://www.justtools.com.au/prod974.htm.
    Good luck with it.
    Aug 2004
    2,312
    If you cant get the grub screw undone and there is the real possibility of damage to it (as in rounding off the head or destroying the screw drive slot)) so it wont come undone anyway, I can talk you through a way that *should* get it undone but will necessitate you "sacrificing" the shower screen.
    Thats not a problem, because you can buy a new shower screen & screw it straight back on.
    My method is the same no matter whether you are dealing with a round headed screw, or a bolt head.
    Before we get to that however, may I say it will be easier for you to use a socket to get it undone (if it is the current bolt head arrangement), as that gives much much better "purchase" by gripping all sides of the bolt head, than using a spanner or shifter because they only grip 2 sides of the bolt head.
    When you eventually get it all off and screw it back in, do it up firm but not tight. Youll know what I mean when you do it...you stop screwing it up when the grub screw simply stops turning, & do not proceed to tighten further.
    Good luck,
    FC.
    Apr 2006
    2
    Thanks all for your encouragement! - I had a good go at it this morning with a short screwdriver that i could also fit a shifter on and got it undone YIPEE!! - about two years of gunk inside that Silvia could well do without. Cleaned it all up and the improvement in taste is just sensational - i will make a habit of it in future. Now - on to this backflushing business........
    Dec 2005
    164
    NIce one Highalt..!
    ive only owned my silvia for around 6 months, the gunk i have seen built up after 1 months use is scary.... i can only imagine what your system looked like.
    Nov 2005
    333
    I tend to updose and after about 10 days (~ 50 coffees) its black as.
    - Rob
  1. silvia shower screen screw
    By thegingerbreadman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2012, 12:16 PM
  2. Silvia Shower screen screw
    By Zaneus in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th December 2010, 09:08 PM
  3. Removing group head screen for descaling - Sunbeam 6910
    By badge61 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd February 2009, 08:51 PM
