Results 1 to 5 of 5
Thread: Another Aeropress/Hario question...
    Feb 2010
    148
    Just ordered this set up from Gregs site to help me in my new job as a psychiatric case manager.
    Anyone notice on the Aeropress instructions that the use of the scoop to measure out coffee pretends that using it for beans or ground coffee is interchangeable?
    Im imagining that there would be a significant increase in coffee grounds if used after grinding rather than using it for measuring the amount of beans used.
    I know these things are trial and error and finding out what works for you - but does anyone feel like sharing how much beans they are using per cup - assuming your filling to the lower end of the 2 or 3 cup measurement (for what Aeropress claims is an espresso)?
    10,496
    Re: Another Aeropress/Hario question...
    I measure my beans into a spare double basket and then grind them into the double basket in the group handle.
    Its close enough to the same for me.
    Try it and see.
    Mar 2006
    703
    As a general guide a scoop will be reasonably repeatable within a small range, if you want to be very consistent for these types of brewing methods then grinding onto electronic scales is the best way, but I dont have any.
    My initial use of Aeropress was using the supplied scoop and the Aeropress suggested short brew time.
    Subsequently I tried some longer brew times with the Aeropress inverted, and have now gone back to a standard ~10g scoop for one serve, and almost twice as much water, which makes about half a cup with some milk, or about 1/3 cup if black. (There is some good info on brewing methods, and links to videos, etc, in the manual Brewing section).
    Despite their claim, the Aeropress does not make espresso, it does make a good filter style coffee, which can be quite strong if you use the supplied scoop and a longer brew time.
    Feb 2010
    148
    Thanks both for the advice. Should arrive tomorrow from Greg so I can start experimenting.
    Mar 2005
    2,165
    Ive only used the Aeropress scoop full of beans when making two coffees. On measuring it, I found the Aeropress scoop holds about 14g of whole beans which explains why.
  1. Replies: 2
    Last Post: 11th March 2013, 08:43 PM
  2. Replies: 2
    Last Post: 24th September 2012, 10:04 AM
  3. !!SOLD!! AeroPress/Hario/Coava combo
    By kanda712 in forum SOLD
    Last Post: 23rd December 2011, 11:35 PM
  4. !!!SOLD!!! - Aeropress and Hario Hand Grinder
    By byron.simpson in forum SOLD
    Last Post: 9th March 2011, 08:14 PM
  5. Aeropress question
    By Lovey in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 19th September 2009, 02:08 PM
