Results 1 to 9 of 9
Thread: Pavoni seal replacement -- DYI?
    Apr 2006
    Woodend Victoria
    104
    I just today confirmed my purchase of a friends La Pavoni Professional lever -- pretty good deal, I thought, at $200.
    It seems tight as a drum but one of the O-rings on the steam wand fell apart as I switched wands .. so maybe I should think about replacing all the seals this year to start with an as-new machine.
    Ive seen DYI instructions on the net -- they sound totally impossible! Has anyone tried it ... is it in fact easier than it reads? The comparative costs are DYI seal kit $62 vs minimum of $100 for a service.
    Apr 2006
    12
    Re: Pavoni seal replacement -- DYI?
    I would also be interested in any info about do it yourself seal replacement for a Pavoni pro...failing that what is a fair price to pay for labour if I already have a complete set of rings/seals ?
    Apr 2006
    Woodend Victoria
    104
    I just found via google search a service agency in Annandale Sydney (uro@tpg.com.au) which quoted me $62 for a DYI seal kit, or around $100 for basic seals replacement plus extra for anything else they found needing attention ...
    The DYI instructions can be found on the net via google search, but they sound pretty intimidating .. which is why I wondered if anyone here has tried it!
    Al
    Al is offline
    Mar 2004
    Eltham, Victoria
    43
    You can do this. Its not as big a deal as it sounds, heres the instructions I got when I first replaced it:
    Make sure you have the following parts, some of which you did not order.
    Dont begin until you have all of them. They should be available from any
    Saeco dealer. If necessary I can get them for you:
    1) The "O"-ring between the brew head and the boiler (about 1.5" dia?)
    2) the small opaque white upper seal (with a ridge on one side) for the
    piston rod,
    3) a brass flat retainer ring with four small holes around the periphery and
    4) the steel spring clip.
    5) the thick basket "O"-ring that surrounds the shower head (inner basket)
    and seals the portafilter when attached to the brew head.
    The spring clip often rusts completely away so that you only find some
    rusty crumbs in its place I will attach pictures of these parts.
    You begin by removing the nuts and spring clips that hold the lever onto
    the piston rod and remove the lever altogether. Then remove the two large
    bolts that hold the brew head onto the boiler and withdraw the brew head
    by pulling the copper tube out of the boiler.
    Now you will need to remove the portafilter seal and shower head. How
    difficult this is will depend upon whether you have changed the seal and
    how hard it is. If it is relatively new you can just pry the shower head
    out with a screwdriver, working around the perimeter. If it is older it is
    best to use a knife to cut it out or if it is really hard, drive a wood
    screw through it and pull it out. Try not to damage the brass brew head
    anymore than than necessary, although small scratches are unavoidable and
    wont cause problems.
    When you have removed the shower head you can push the piston rod all the
    way through the brew head by pressing down on a wood surface and then
    pulling the piston out.
    Now look up into the brew head from below. You should see the (remains of)
    the steel spring clip. If the clip should still be intact you will need to
    use some kind of a tool (awl or special pliers) to remove it. Then pull
    out the brass ring (you may damage it, therefore it is best to have a new
    one) and the old silicone rubber gasket. The old gasket, by the way, may
    be black. The new ones are an opaque white.
    Clean up and wash out the inside of the brew head cylinder, insert the new
    opaque white silicone upper seal with the v-shaped notch facing towards
    you, the brass ring and then the steel spring clip. This takes some
    fumbling around if you dont have a special long-nosed spring-clip pliers
    to do it. Take your time with it. It is possible with just an awl and a
    normal long-nosed pliers.
    Check the two, thick piston gaskets. If they look alright you can leave
    them, or if you have new ones you can replace them to be sure. They
    usually arent prone to wearing out.
    Now comes the part with the lubricant. The easiest was to get the
    lubricant is to buy the "Brew-group service pack" for Saeco full-automatic
    machines because these packs are readilly avaiable. Here in Germany they
    can even be found in normal larger departments stores. They contain 2
    gaskets that you wont need (unless you have a Saeco auto) and a tube of
    white, food-quality grease. This is the bit you need. You can also get
    food-quality white-grease from specialty service stores, but if you had
    one of them available you probably would not have asked about where to get
    this. Alternatively, I can also send you some. Dont use anything else on
    the Pavoni or you are asking for trouble or at least a bad flavour.
    Once you have the lubricant, put some on the shaft and on the piston seals
    and re-insert the piston into the cylinder. Then put the whole thing back
    together the way you took it out. Getting the portafilter seal and shower
    head in is a bit tricky and it helps if you put a little of the lubricant
    around the perimeter of the seal so it can be pushed up into the brew
    head. Finally, bolt the brew head back onto the boiler using the new
    "O"-ring.
    Thats the instructions Bruce in Germany sent me and I found them easy to follow once I stopped worrying and just did it ;) Send me an email at seal.5.alsmith@xoxy.net if you need more info, Im not checking the forum often enough! If youre close enough to Northcote you could even come around and Ill show you :D
    Apr 2006
    12
    Al,
    Thanks for such a comprehensive set of instructions...I may just give it a go!
    Apr 2006
    Woodend Victoria
    104
    Yes indeed, thanks heaps.
    17,406
    Good one AI [smiley=thumbsup.gif],
    Great to see CSers helping out fellow members with such concise information..... keep up the good work 8-),
    Mar 2004
    42
    Good work Al, agree with most of what you said, except on removing the shower head. I find if you take a mallet and softly tap the top (after removing the lever & bolts, of course), the shower head should drop off easily. It the shower head is stuck, wrap a piece of cloth around the top, and give it a few harder knock, this should dislodge the shower screen. This way, the shower head wont be demaged.
    By the way, anyone found the Saeco "brew group service pack" in Australia?
    slow
    Al
    Al is offline
    Mar 2004
    Eltham, Victoria
    43
    Im with you slow, I disagree with what I said as well ;) Its definatly easier to use a mallet. I think the machine Bruce got was in much worse condition, hence where he says:
    You should see the (remains of) the steel spring clip. If the clip should still be intact you will need to
    My circlip was in perfect condition, and Id recommend getting a cheap pair of circlip pliers rather than playing around trying to get it out any other way.
  1. Price of a replacement EM6900 seal
    By stevenroberts in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th January 2010, 01:57 PM
  2. Replacement seal for Ascaso Dream
    By Groupie in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th March 2009, 08:10 AM
  3. EM6900 group seal replacement
    By Meeks18 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd September 2008, 11:28 AM
  4. Sunbeam Ristretto seal replacement?
    By garymck in forum Brewing Equipment (non-machine specific)
    Last Post: 1st July 2008, 06:26 AM
  5. Gaggia seal replacement?
    By AndyCJ in forum Brewing Equipment (non-machine specific)
    Last Post: 10th March 2006, 05:27 PM
