Results 1 to 3 of 3
Thread: 2 group home machine modifications
    Sep 2005
    509
    I have an Ariete Futurmat 2 group machine plumbed-in and connected to a timer switch that I have pre-set so that the beast is raring to go the moment that I get out of bed each morning and again when I arrive home in the evening. What a spoilt snob am I!
    The Futurmat takes around 20minutes to get up a full head of steam from dead cold as it has a 13 litre boiler....herein lies the reason for my message:-
    1)Should I periodically empty and renew the constantly filtered water in the boiler? (say each month or so).
    2)Is there a way of tricking the fill-up sensor so that the boiler doesnt require the full 13 litres of water to operate? (I realise that the water level gauge and sensor warning light only work properly when the full 13 litres is present).
    I would appreciate any input from fellow coffee addicts.
    Thanks,
    Paolo.
    Aug 2004
    2,312
    Re: 2 group home machine modifications
    1) All you need do is pull say, a litre of water out of it every day. That way it will replenish with....a litre of fresh water.......every time you do this.
    Is it advantageous to flush out your boiler periodically? I dunno.
    You have to ask yourself why you might do this. Yes the water in the boiler is stale, but it doesnt make the coffee, it is only the source of the heat for the heat exchange to the fresh water that your espresso is made with and, it produces your steam. Does it matter if your steam is produced from stale water? I dunno!
    2) Dont do that or you will affect the machines ability to produce coffee, steam, and recover, from the way it was designed & built to do so by the manufacturer.
    3) This is tangential to your questions however if the boilers capacity is said to be 13 litres then it does not mean the boiler actually contains 13 litres of water! *;) *An espresso machine boiler would generally be set to fill to somewhere roughly between 1/2 and say 2/3 of its total capacity, leaving plenty of room for steam and the ability for the machine to reach proper operating pressure/temperature as a result so as to be able to do the "job" intended which actually is to do the "heat exchange" to the fresh water coming through to brew coffee with!
    In any case what I am saying, is there is probably only say 8-9ish litres of water in there but whos counting!
    Regardz,
    FC.
    Sep 2005
    509
    Thanks FC. What you have said makes sense to me.
    Regards,
    Paolo.
  1. Whats a good used two group for home use ?
    By NakiChap in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th April 2013, 07:32 PM
  2. Replies: 5
    Last Post: 28th June 2010, 10:18 AM
  3. Visual machine modifications
    By trentski in forum Brewing Equipment (non-machine specific)
    Last Post: 12th November 2009, 10:27 PM
  4. La Cimbali M27 2 group, ok for home machine??
    By borat123 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th June 2009, 12:00 PM
  5. Single Group machine for home use
    By gonetroppo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st October 2008, 05:34 PM
