Results 1 to 7 of 7
Thread: coffee dispensing pressure gauge
    Oct 2010
    14
    I have a Grimac ILE Model (Twenty) The coffee dispensing pressure gauge in the manual said that it should be between 910 bars. It sits at 6 and when extracting it goes to 7. What do you think may be wrong? Any help would be greatly appreciated.
    10,496
    Re: coffee dispensing pressure gauge
    Either the guage is wrong or the pressure is set too low.
    Oct 2010
    14
    Thank you for your reply. Even when the machine is turned off and cold the coffee dispensing pressure gauge sits the same as when it is on, at 6 bars. It seems to be extracting espresso ok??? I am just worried that if there is a problem with the machine and i continue to use it it may make things worse. Any ideas on how to set the pressure gauge. Cheers dashadoo
    10,496
    Ok, now weve established the gauge is wrong (not working).
    Sorry, Im no tech.
    Someone else will now have to take this further for you.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5569746F656473666E65010 link=1287404189/3#3 date=1287452363
    Sorry, Im no tech.
    Where did you buy it from ?
    Depending on teh cause (unknown) it may or may not make things worse to keep using.
    A blockage in teh line ? Or a gauge that is stuffed.
    Try 9Bar Espresso Services if your supplier is not able to play ball.
    Dec 2004
    Earth!
    15,570
    Quote Originally Posted by 1F233E252F2E392C242F4B0 link=1287404189/3#3 date=1287452363
    Not necessarily.
    Quote Originally Posted by 2F2A38232A2F24244B0 link=1287404189/0#0 date=1287404189
    Quote Originally Posted by 2F2A38232A2F24244B0 link=1287404189/2#2 date=1287450566
    While your gauge may be stuffed these statements could be interpreted as, unless your machine is a tanked model, the gauge is reading line pressure and the pump is not working at full pressure. This could be either because it is stuffed or, if its a rotary, it is set too low.
    You need to test the gauge by eliminating the line pressure from the equation. With the machine cold disconnect your water line and see if the gauge then reads 0. If so then the odds go up that the gauge is reading correctly and the problem lies with the pump.
    Java "The bill is in the mail." phile
    Oct 2010
    14
    Thank you all for the replies. I will do as you advised javaphile tomorrow. However the plot thickens....I just noticed that when i was doing the dishes and the kitchen sink tap was on (the water inlet for the machine is on the same line as the kitchen sink) the gauge went crazy. It went up when the tap was on and then went down when i turned the tap off. Any ideas? Cheers Gary
  1. EM6910 pressure gauge stopped working...bitter coffee!
    By martrix in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd May 2015, 04:53 PM
  2. pressure gauge
    By Gra in forum Brewing Equipment (non-machine specific)
    Last Post: 7th May 2012, 06:27 PM
