Results 1 to 4 of 4
Thread: Electronic pressure control
    Apr 2005
    1,176
    Woo hoo! I just got my electronic pressure control idea tested and it works.
    Still a few things to sort out, but I turn a dial and the electronics changes the pressure. The first stop will be variable and adjustable pre-infusion (ie pressure and time) and adjustable brew pressure. Eventually I might look at pressure profiles as well.
    The good thing is no fancy pumps are required. These are all off-the-shelf components and relatively cheap (sourced from coffeeparts. Thanks Pedro).
    Mark.
    Dec 2004
    485
    Re: Electronic pressure control
    Cmon Sparky, you cant leave it there.
    Tell us more, any photos or perhaps a description?
    Apr 2005
    1,176
    Im keeping the lid on this one for now. Besides Ive only shown proof of principle, not a working device. Ive also modified the key component a bit, as it is not designed for what I want. For example Im using it backwards. Theres also an inbuilt hysteresis that Im trying to get rid of.
    I post more if I get it running more smoothly with the mods Ive made...
    Dec 2004
    485
    Hmm is it a dust buster with a variac :)
  1. BZ40 - group head pressure not stable when adding water pressure limiter
    By pup26 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th March 2012, 08:24 PM
  2. Boiler pressure - small high pressure boilers
    By dane5431 in forum General Coffee Related...
    Last Post: 6th May 2011, 04:16 PM
  3. Installing a pressure gauge into an Expobar office control
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 5th September 2009, 08:31 PM
  4. Macap Electronic Grinder
    By TC in forum Grinders
    Last Post: 22nd January 2008, 01:11 PM
