Results 1 to 7 of 7
Thread: PID a Hot water urn ??
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    I noticed Seven Seeds had a PID on their hot water urn and I have an 8 litre stainless urn and wondered if it was worth doing for cupping or larger pour over sessions.
    My question is what benefit would I be getting over just turning the temp dial to 95 or whatever temp I was after? I guess for pour over most kettles with a temp dial would keep up (1.7L at 160ml cups) so that would just leave a cupping session of say 4 people and 200ml cups. I think I have answered my own question, probably best suited for bigger numbers of people and coffees?
    More than likely I just wanted another gadget that cost less than an Uber ;D
    Jul 2008
    Port Fairy
    2,993
    Re: PID a Hot water urn ??
    Closer tolerance (still only +/- 1 degree if you use a K type TC) and easier repeatability with a PID/SSR combo. To get it more accurate you would need to go to a better quality TC.
    Usual things too play carefully with high voltage it kills the tinkerers and the "experts" alike
    Jun 2008
    1,520
    you could use one of these *Temp controllers on the bay
    says good to 99
    i use one on my temp controlled fermentor fridge (beer making) and happily switches 10amp
    they have a cheap plastic temp senor but, not sure if you could switch it to a SS k type easy
    Oct 2008
    505
    I tested my urn (5 litre Birko) and found that the temp varied up to 15 degrees from where it is set. I put it on 80 degrees and find it turn on at 82 and off at 97.
    Worse still these numbers change as the urn heats up or down. At cold the urn turns off at 90 and on at 75.
    Not the best thing to hear if you are using an urn for cupping.
    So a PID will lock down the temp far better. Got to build me one of those things.
    Feb 2006
    2,334
    Quote Originally Posted by 2532332D383932666566570 link=1288408988/0#0 date=1288408988
    Well lets put it this way, the Uber would struggle to do a big cupping session.
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    Quote Originally Posted by 674543585F5543300 link=1288408988/4#4 date=1288526513
    I dont know about that in terms of only PIDing something for large numbers, were going to PID the kettle so I stop burning the coffee (granted we didnt realise how long our kettle took to get down to the right temperature until tonight) :D
    Oct 2010
    483
    Dont hesitate just do it. Ive just installed a PID on my gaggia and wish Id done it sooner. At under $40 for a PID and SSR from the bay (in usa) it is a pretty small investment. You wont regret it.
  1. Water treatment - Scale inhibitor Vs. water softner
    By prloring in forum General Coffee Related...
    Last Post: 11th February 2012, 10:04 AM
  2. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 04:16 PM
  3. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 01:53 AM
  4. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 10:43 PM
