Results 1 to 15 of 15
Thread: My 20 yr old Mas tripped the Earth Leakage
    Dec 2005
    370
    I havent used it for a month or two and plugged it in to try some Italian Beans I got thru the post..
    Bang out to the meterbox and Bang again..
    So I did an exploratory and can see nothing that would cause problems..
    ???? Its a Simple Machine 3-4 inch long tube pump and a 4 inch Dia, boiler/Split low side Group output Highside Steam3 switches and about 18 wires ..
    ???? Do i need a Megga to Test it ??? Know plenty of Leccos who owe Favours or can I test it with my Multimeter??
    How as Im a DIY sort of guy..
    As an aside I Contacted Lygon Imports re this unit - 20 yrs old and the Nice Girl Said we have never Sold this unit..
    Sent her back an Email, Pointing out that it may have been before her time (and I was polite there )
    and mentioned the little Foil Label on the boittom that gave all the Info [Agency LYGON IMPORT] and the Tel number was (03) 486 1572
    and said your move Sweetie , Havent heard back from her yet!
    Tepin
    17,378
    Re: My 20 yr old Mas tripped the Earth Leakage
    Hi Tepin,
    Have never found Lygon Imports to be particularly responsive to any of my requests over the years.... perhaps they have a preference for dealing direct with retail vendors and not we mere consumers :(.
    Regarding your E/L query, I would definitely recommend that this problem is best determined and rectified by a licensed sparky. You can of course check under the bonnet and try to spot any obvious signs of wire insulation chafing, or black sooty deposits (all this with the unit unplugged from the GPO of course) as this may reduce the time (and therefore cost) that a sparky will have to spend carrying out repairs.
    Aug 2004
    2,312
    Agree entirely with Mal...
    However, just a little further information that may interest but is really only "academic". Mostly when we are brought machines exhibiting this kind of problem, it turns out to be the electric element.
    Very often, the earth leakage circuit picks up a fault that would otherwise go undetected through wiring that is not connected through an earth leakage circuit (as in, wont trip out regular circuit breakers). This sometimes catches out people that are moving from one home to another, and the new home is more modern & has an earth leakage circuit combined into the electrical fit out...all of a sudden appliances that worked "perfectly" in the old place, set off the earth leakage circuit in the new place...
    Doesnmadder...get it fixed because it indicates a problem.
    If you are going to ring Lygon Imp. about something that old, you have to ask for Eddie, the girls grandfather, the fellow that started the business.
    Regardz,
    FC.
    Dec 2005
    370
    Quote
    Thanks FC thats Priceless..
    A name is sometimes all it takes..
    Young Daniela Parisi was the Culprit who emailed me back ,Ill nudge her along this morning..
    I have played Electrician before a few times and lived to tell the tale..
    Thanks Mal
    Funny I asked a Sparky this morning and he must have been just a drone working under his bosses License/ Funny you get a bit of that in that trade// I Have 30+ years of background in the Painting Industry, mainly Commercial the last 20/// Ill see a Mate Today and get him to track the Fault//// Nothing Obviously burnt or loose..
    Tepin
    17,378
    Yep,
    Know what you mean there Tepin. Some so-called wire-jerkers go under the pseudonym of Electrician and one has to wonder how on earth these sorts of jokers are allowed to be let loose among the general public at large, with a license yet :-?.
    Anyway, any half decent sparky with a commercial or industrial background should be able to help you out and like FC said, its more than likely going to be the element but it pays to be both safe and sure. All the best,
    May 2005
    Perth
    1,261
    You could try a circuit board spray or similar around anything that looks dirty inside and see if that helps.
    The earth leakage detector is a godsend though.
    Even moisture or water in an appliance can trigger it as well as any sort of conductivity between components which can result in leakage of current.
    I think FC is right that your element is the most likely cause. You can get someone to check the resistance with a multimeter and find out pretty quickly.
    Grant
    Dec 2005
    370
    Looks Like the Element/ Had a Mate / Not a Leco..
    A Very Highly Qualified Air Con Engineer;Ex York] ,
    run his Multi over it ..
    A Fluke which I lust after..
    Got a Mate in the Pistol Club who makes Elements for the Plastics Injection industry, so its off hat in hand to visit him..
    Update re LYGON IMPORTS {for MAL}
    The dear young girl Daniella parisi has not replied to my last 2 email, first one clarified that Lygon actually sold the unit [She told me they did not] second one asked her to ask Eddie the original owner Proprietor..
    So it looks like I have to spend a couple of bucks tomorrow making a Phone call..
    Sadly for her if I make the call, ill go for the Jugular..
    Tepin
    17,378
    Quote Originally Posted by TEPIN link=1150198820/0#6 date=1150373914
    Tepin
    Hmmm,
    Sadly, that seems to be the norm for them..... hope you get a satisfactory result though,
    Dec 2005
    370
    Im only after a handle/ maybe a spare Porta Filter/ a spare Screen,
    Ahh well I look like im forced to use my command of the English Language/Inflections etc
    I can get away with that statement as English is my second language..
    I have a rather bad phone manner with Fools..
    Tepin
    Aug 2004
    2,312
    Hey Tepin,
    dont feel bad, you are not being singled out...see Mals comment "...Sadly, that seems to be the norm for them....."
    If this is genuinely the norm, then they may be quite used to receiving and then probably ignoring bad telephone manner as exhibited by callers. You might surprise (both them as well as yourself) if you adopt a totally opposite approach, very politely say you are concerned that your emails went astray, and advise that you really *really really need them to help you...now...
    And then, maybe that wont work either..I dunno, never tried that one!
    Eddie Parisi is the girls grandfather, or grandfather in law. As far as I know he still goes in "casually", but the grand kids basically run the show. Whatever. *If you get to talk to him he is softly spoken and very knowledgeable about the equipment he has sold / sells....so dont forget to be nice or maybe they wont let you talk to him *;)
    One last point about contacting companies by email...email traffic has increased exponentially with companies now virtually needing to keep someone sitting at a keyboard all day replying to what really amounts to...a high proprtion of time wasting enquiries. This ties up one whole employees wages on stuff that in many cases doesnt bring any income. Lots of people make enquiries by email because they dont want *personal contact, and you spend an hour basically replying to stuff that would only have taken 5 minutes to answer by phone. (please dont think I am saying your enquiry is a time waster..far from it if you need service. I am just making a very general observation).
    Some companies dont handle this very well and just ignore email thinking, that if the topic of dicsussion is really that important to the email inquirer, then he/she will finally telephone when they dont get an email reply.
    Takes all kinds!
    Trouble is, when they eventually phone up, *the frustraion it sometimes results in a less than polite telephone manner.
    Suggest to all, that use of the phone is still the best way to get results in the first place as it makes a personal connection with someone rather than with a machine.
    Sincerely Hope you get the result you want.
    Regards,
    FC.
    17,378
    Hi again Guys,
    A lot of what you say is true FC, but even if you use the "Contact" page on Lygons very own web page, it is still very much pot luck as to whether you receive a reply. For someone in my position with extremely limited income and living in the Qld bush, making STD phone calls to try and chase up someone who even seems to ignore their own web-based contact system, borders on an extremely futile expenditure of ones time, effort and money. I much prefer to deal with businesses such as yours who at least find the time somewhere in their busy schedules to respond to genuine queries.
    In the case of my Mokita, I eventually tried contacting the factory in Italy and via this back door, Lygon were then encouraged to contact me. After many frustrating months with plenty of respect and courtesy proffered from yours truly, my problem was eventually solved. I really dont want to have to go through that again I can assure you :(,
    Aug 2004
    2,312
    Very fair points Mal.
    Regardz,
    FC.
    Dec 2005
    370
    Well I had some time up my sleeve/ Actually made some time and did some intensive Internet Searches/ WHilst i was not really successful in finding the Mas /
    I did find an Express 2000 which is also give on the bottom foil sticker as well as a Mario ?
    This I found in an Argentine Website.. It looks like my MAS may actually be an Early Imat / Similiar to the Mokita but with a White Epoxy painted Body..
    http://coffeesnobs.com.au/YaBB.pl?num=1136631600
    The Steam wand is on the RHS on mine
    Daniella Got back to me Friday by email so I did not get to use my phone skills..
    and she had actually asked Eddie [thanks go to F.C. here], she is going to get back to me as those parts a in another wharehouse..
    Regards Tepin
    17,378
    Great news there cobber [smiley=thumbsup.gif],
    May 2006
    51
    Gday All,
    After reading polls like this I was getting a bit worried about dealing with Lygon imports. After waiting for a reply to my email I decided to ring them. The results I got om the telephone were very impressive. Daniella was very helpful and my parcel arived 2 working days later.
    Thomas
  1. Futurmat Ariete 1gr - how to handle tripped Level Safety device
    By nkb in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 2nd October 2011, 07:36 AM
  2. Silvia earth leakage
    By Derrick in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th October 2009, 12:35 PM
  3. Help, Gaggia Classic coffee earth leakage after cleaning
    By stevepole in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th June 2009, 04:11 PM
  4. Napolitana earth leakage again :(
    By dsgfh in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd September 2007, 09:14 AM
